Yuyang king 40amp controller
Sidotian   10 W
Re: Yuyang king 40amp controller
Post by Sidotian » Oct 28 2017 3:51am
No it says cannot open
x.l.r.8   100 W
Post by x.l.r.8 » Oct 28 2017 3:51am
Also android or IOS
Intelligence is distributed nearly evenly, with only the occasional concentration in one person. The total quantity of Intelligence is a constant: as more people come into being, fewer and fewer get a sufficient amount for themselves.
Some say this has already reached homeopathic levels.
Sidotian   10 W
Post by Sidotian » Oct 28 2017 3:52am
Android Motorola moto
x.l.r.8   100 W
Post by x.l.r.8 » Oct 28 2017 3:53am
Then you need to either reset or use a different app
Sidotian   10 W
Post by Sidotian » Oct 28 2017 3:54am
What other app? Is it possible to program via pc and usb?
x.l.r.8   100 W
Post by x.l.r.8 » Oct 28 2017 3:56am
did you try 4 finger swipe upwards
password 'akili123'
might work
I use IOS and the daymak app works well, even with their stock motor and my 2 hoverboard packs wired in series i can get 50km/hr
x.l.r.8   100 W
daymak app
Sidotian   10 W
Post by Sidotian » Oct 28 2017 3:57am
What's the 4 finger swipe? and I'll try the daymak app when I get out of work in a few hours
Sidotian   10 W
Post by Sidotian » Oct 28 2017 7:31am
I tryed daymak it lets me see the setting in that app but here not right and if I try to save a setting change it says sending and gets stuck there
x.l.r.8   100 W
Post by x.l.r.8 » Oct 28 2017 9:55pm
And what are the settings?
Sidotian   10 W
Post by Sidotian » Oct 30 2017 3:02pm
It's basically what it would look like right out of the box... What the settings say in daymak is not what they actually are for example the amp limiting says it is off but in reality it's on no matter how long I wait it won't do anything ... Is there a way to reset the controller with out a phone/app?
It also never asked me for a password which I thought was odd
paul drury   10 mW
Post by paul drury » Nov 05 2017 9:56am
Good afternoon Fetcher,
I have tried with the speed limit on and off, I have tried with eco mode on and off and no difference, I have tried the vehicle calibration in the app but with no success as when I click obtain for the starting distance it just sits there saying getting and I can get no further, would this be the possible cause for my problems or is this calibration only used for the speedometer on the display?
thanks
Paul
fechter   100 GW
Post by fechter » Nov 05 2017 11:46am
As far as I know, the wheel size setting will affect the speed limit.
jordanjozsef   1 W
1 W
Post by jordanjozsef » Jun 14 2020 4:07pm
I'm having problems with my controller too, the calibration doesn't work for me neither, it gets the start distance, but nothing happens when I click obtain at the end distance. Model is YKZ12080EA, my friend has Ykz7280JA, so the only difference is the voltage rating, but he can set the high speed ratio up to 30, but mine can't be set over 15. The same motor with his 72V controller spins faster than my 120V. Higher voltage, but less RPM. Makes sense, right?
fechter   100 GW
Post by fechter » Jun 14 2020 8:48pm
That model is different than the old one I worked on before but it may have some of the same features. The old one had a "speed limit" jumper you either connect or disconnect (grey wire). There was also a 3-speed switch. In speed 1 or 2, the limit will be lower. Make sure you have it set on speed 3.
jordanjozsef   1 W
1 W
Post by jordanjozsef » Jun 15 2020 4:55am
It's in high speed mode, and it's faster, the high speed ratio works, but can't be set over 15.
fechter   100 GW
Post by fechter » Jun 15 2020 9:11am
The "speed limit" jumper on the old model was a pair of single wires with connectors that come out of the controller. Not sure if you connect or disconnect to disable the speed limit. Are there any unused single wires?
jordanjozsef   1 W
1 W
Post by jordanjozsef » Jun 15 2020 12:17pm
Only the 3 speed switch is connected, I don't use the others. I think the controller doesn't support that high speed, but I don't know why, if the 72V version supports, why not the 120V version?
fechter   100 GW
Post by fechter » Jun 15 2020 9:45pm
Look for a pair of unused single grey wires with connectors that can plug in to each other. That's how the speed limit thing looked on the old one.
mestari   1 µW
Post by mestari » Aug 01 2020 11:30am
Hi,
I just bought this same controller (YKZ7280JA) and I am using it with a 60v battery. The same problem with the overspeed configuration appears in my setup also.
Using the default calibration the APP shows about 38km/h (~24mph) and that is roughly what my GPS shows also when I drive my scooter.
I have the current limit set to 100% and 3-speed selection in high speed. The overspeed does have selection for 30 but when I save it falls back to 15.
Just got the controller connected but I did not test the road speed before that :(
The grey wires in this model are disconnected and connecting them just disables the soft start, no affect on the speed.
I see that some people using this same controller has gotten then overspeed value 30 working. What version of the Yuyang king APP are they using? Or does the controller somehow make that decision (to use value 30 or 15) based on the voltage?
