Edge 1,500 and 3.25mm spoke holes and 13ga 2.25mm spokes
999zip999
100 TW
Dana Point So. Cal
Drill new holes ? What size ? Or get concave bass washers. The washes may take up slack but maybe to much for elbow room ?
So sunrims ryhno lite 6000 series 559x27mm with eyelets, spaim 168mm 13/14mm ( 2.25mm) spokes and edge 1,500 motor with 3.25m holes
Just get some M2.5 or ANSI #3 washers and put them under the spoke heads.
I think so I have seen concave brass washers. I do have dapping puches for dishing and metal and wooden block if needed. Will search es for washers.
The spoke heads will form the washers as they're tightened. You don't need to pretreat them.
I second Chalo. It's worked wonders for me, on motorized and pedal hubs alike.
The key is to move the straight section of spoke as close to the flange as possible, so the J-bend won't get stressed under load.
McMaster-Carr
https://www.mcmaster.com/
Brass Washer
for M2.5 Screw Size, 2.7 mm ID, 6 mm OD
Zinc-Flake-Coated Steel Wedge Lock Washer
for 9/16" and M14 Screw Size, 0.6" ID, 0.91" OD
M2.5 stainless flat washers:
http://ebay.com/itm/U-S-Seller-304-Stainless-Steel-Flat-Washers-Metric-M2-M2-5-M3-M4-M5-M6-/112029373777
Less than 3 bucks for a wheel's worth, shipping included, USA seller.
Whatever suits you. I've used a lot of brass washers for the same job, and I've had no complaints so far. The cold work applied to spokes makes them much harder than stainless washers, though, even if the alloy is similar.
