I'm looking for help regarding twist throttles. My new bike has one, but I would like to use it more as a cruise setting facility, and to ride with throttle feathering. The problem is probably aired before, namely that braking will not cancel it, so on releasing the brakes power is restored which is undesireable.
Using it as a control for the level of assist is therefore not practicable, and when it is left at zero, power deliverded as pedal assist occurs is unlimited up to 15 mph cut off. I believe twist throttles are also illegal in UK now unless the rider has to intervene continuously to keep it so.
Is there any way of ot being only enabled when pedalling?
Any suggestions welcome, thanks, Robert.
