Controller Wiring Help with Ignition
hedgecore08
Post by hedgecore08 » Sep 16, 2017 12:16 am
I just purchased a 48v 500w controller from Ebay and I feel confident in all the wiring except the ignition. The controller I bought only has one red wire for the ignition and I have a feeling I should run it to a switch and then to the power (positive) somewhere. Though I am not totally sure though, since most controller have two wires for the ignition from the controller.
There is a horrible wiring diagram on the ebay page if you wanna take a look. haha
http://www.ebay.com/itm/48V-500W-Electr ... SwsTxXjESP
dogman dan
Re: Controller Wiring Help with Ignition
Post by dogman dan » Sep 16, 2017 6:46 am
A bit confusing as there is two diagrams on that page.
I am not sure what to make of this one, since there are wires for burglary power, power switch, and signal theft.
I would think power switch would be the one to connect to battery, through a switch, if it was red. looks like another color to me though. :?
I'd start with just trying the two power wires, see if it does power up. If not, start asking the vendor WTH?
Use a stout plug for the switch if you get it powered up. Switches on the main battery wires just fry, unless they are expensive, heavy contactors.
Voltron
Post by Voltron » Sep 16, 2017 9:39 am
On my generic Ebay controller the single red was the ignition, and yes, either directly wired with the battery positive, or thru a switch. I highly recommend a barmount switch for safety.
The smaller black/red combo on mine was full pack voltage out for dc/dc converter hookup... and for confusing, mine has the same anti theft, doorlock, etc, and at least five of the different things had a paper tag around them that said Hall wires...lol.
