This morning I pulled my bike out to go to work and got no response to the throttle; it juddered once and stopped with an error code.
(Bike: HSR3540 motor 26” rim, PhaseRunner, Cycle Analyst V3, Lunacycle 54V battery)
I power cycled it and hoisted the rear wheel up. I gave it some throttle and the rear wheel spun. I stopped it with the regen brake, and then it wouldn’t start up again. Same error codes - 2-2 and 1-6 (phase overcurrent and Hall sensor failure)
The throttle input into the PhaseRunner is fine. Errors reported via the PhaseRunner app are:
Faults[9]: Instantaneous phase overcurrent
Warnings[7]: VdcLowFLDBK
I figured my next step was to check Hall sensor outputs and phase inductances (or at least resistances) but the motor phase-wire connector has welded itself together. I couldn’t get them apart even with two pairs of pliers. Will check Hall sensors tonight at least; I should be able to do that with everything powered up by spinning the wheel manually.
