Bouteille51
Hi all,
for my next build, I plan not to use a cycle analyst, but a simple throttle connected to the controller (phaserunner).
However, in case water gets in my cheap throttle (or any other stupid thing) I'd like to integrate a HWBS sensor on my brakes (as an extra safety to fault voltage detection in controller).
If I understand correctly this sensor connects the signal wire to ground when the brake is used.
Do you know whether signal is pulled high or wire is "left floating" on rest ?
I ask this question because I wonder if it would be possible to parallel connect the 3 cables of the throttle and the sensor...
If "left floating", the throttle signal would be allowed to drive signal while riding, and when braking the sensor pulls it to ground (whatever the throttle is doing).
That sounds a bit too easy actually
