Leili controller+ TFT display
elik1111   10 W
Post by elik1111 » Oct 30 2017 8:46pm
Is anybody using this set of square wave 80A controller+TFT display?
Had anybody had noise and shaking problem in a low speed or climbing up? How did you fix?
In addition, suddenly the TFT died and won't start. In this case the controller stops working as well.
Anyway to bypass this TFT or its a must.
I do like the advanced featureless of this controller as: lights and alarm, but God so many problems with this monster sized controller.
Any suggestions?
Tkseward   10 mW
Re: Leili controller+ TFT display
Post by Tkseward » Nov 05 2017 5:14pm
Yes I am experiencing the same exact problem. They literally sent zero setup information with the kit. Mine makes a lot of noise under load and it shakes/slips at a specific range in the rpm.. I am going to contact Leili about this.. Was going to order 200+ units of this kit, but now I am not too sure about them..
elik1111   10 W
Post by elik1111 » Nov 05 2017 5:36pm
I had the same since June. In the beginning they had blamed it on the fact of the controller being a swuarewave which is bull. I insisted on solution and finally they had send me a new controller with I guess a new software version. They had fixed 70% of the noise and shake.
But... Now the TFT is not working. The problem is that it's a closed system and not competable with CA.
amberwolf   100 GW
Post by amberwolf » Nov 05 2017 6:19pm
The SA version of the CA is compatible with everything, for monitoring.
Anything that uses a 5v (max) throttle or RC-pulse throttle can also be controlled by the CA. You just have to do some rewiring of your kit to connect it's throttle up to the CA, and the CA to the controller's throttle. If it uses JST connectors then even taht is easy, just making sure the pins are in the same order. If not, you just need to either change connectors to match, or directly splice the wires together.
All the info necessary to do it is on the http://ebikes.ca site, on the CA product / info pages, and in the manuals and step-by-step guides downloadable there. (there are also threads here on ES about it, but harder to find).
elik1111   10 W
Post by elik1111 » Nov 05 2017 6:59pm
Yes i m familiar with the CA. How ever their controller is not stand alone. Their TFT must be connected during all times. I verified it with them.
amberwolf   100 GW
Post by amberwolf » Nov 05 2017 7:08pm
You could leave the TFT connected but bundled up off the handlebars, if you dont' need any of the info it is showing you, and don't need to press any buttons on it while riding. If you have a battery bag or box you could stick it in that.
elik1111   10 W
Post by elik1111 » Nov 05 2017 7:38pm
Correct, that's ok if the TFT is working. Mine stopped working.
amberwolf   100 GW
Post by amberwolf » Nov 05 2017 8:18pm
Well, if it's like the other controllers that "require" their LCD, some can be run "headless" by finding the two wires that act as "keyswitch".
In other controllers like my Fusin kit, which used a LiShui controller and I think a KingMeter LCD, there is a wire with battery voltage on it, and another wire with no voltage on it when the unit is "off" but after you engage power with the buttons connected to the LCD, the second wire then also has battery voltage on it, passing it back to the controller.
Since yours doesn't work you can't measure for this, but anyone with a working LCD would be able to do so.
Once you know which two wires they are, you can just connect them together, with or without the LCD attached at all, and the controller should operate at least in basic mode. It may only work at the firs tpower level if there are multiples, if those levels must be changed every time you power on.
Another way to find the wires may be to open the controller, and find the thin wire that goes from the input side of the low-voltage regulator to the connector on the LCD. That wire would be teh one that gets power from the LCD when the LCD is turned on (button push), and so would be the one you'd need to connect to battery power to turn it on.
This post
https://endless-sphere.com/forums/viewt ... 66#p584366
has that info for my controller; the arrangement is likely similar for yours.
elik1111   10 W
Post by elik1111 » Nov 05 2017 8:47pm
Yes, I asked Leili that question but they did not want to tell me.
I hope they will send me a new LCD and will get it done.
Tkseward   10 mW
Post by Tkseward » Nov 05 2017 9:11pm
I just rode mine today and the LCD froze. I turned it off by unplugging the battery as the RFID keys wouldnt shut it down. I have a second display and it worked when plugged in. I rode it home and tried the other display that wouldnt turn on previously. Well it started right up.. im not sure whats up but we are having thr same issue. I bought this kit in late spring/early summer. Sounds like we got screwed.. ive used plenty of controllers and this shit is bs.. can you pass along LEILI's contact info? My contact quit working there due to no agreeing with how they do business.. (red flag)
Tkseward   10 mW
Post by Tkseward » Nov 05 2017 9:18pm
Better description.
My original display froze and it wouldn't turn off.
I tried opening up and looking in side and seeing if there is anything visibly wrong and everything looked okay.
So I went home got my spare display for another kit that I was going to set up and that one fired right up when installed.
So I wrote it home and when I got home I decided to see if the display that wasn't working with turn on again.
The display turned on and everything was working okay.
So something seriously wrong we need to figure it out
elik1111   10 W
Post by elik1111 » Nov 05 2017 9:21pm
Is it their original TFT?
Tkseward   10 mW
Post by Tkseward » Nov 05 2017 9:44pm
the color TFT. i dont know if its original or not. it was purchased nearly 6 months ago
Tkseward   10 mW
Post by Tkseward » Nov 05 2017 9:46pm
can you provide your contact to Leili? I cant get a hold of anyone there. Their contact info goes to a women who doesnt work there anymore. I just talked to her on the phone and she said the system for the TFT software is unstable because it is so new.
elik1111   10 W
Post by elik1111 » Nov 11 2017 5:44pm
Received a new TFT. Let's see if this one works:) if not I, m going to get new controller that works with a phone or CA.
FlyingFinn   1 mW
Post by FlyingFinn » Jan 11 2018 11:26pm
Any updates? Still same problems? If the problems persist I will buy something else for my future build. Your answers are much appreciated :D
elik1111   10 W
Post by elik1111 » Jan 12 2018 6:40am
The new controller works much better. There are some shakes in a certain very low speed but much better all together.
adaoud   10 µW
10 µW
Post by adaoud » Jan 16 2018 12:18am
elik1111 wrote:
Nov 05 2017 5:36pm
Hi, i was communicating with their sales rep "Chris" & he told me the same bullshit, after 2 months of investigating, he quit the company & i had to retell my story countless no of times to countless number of people. i'm curious though, how did you solve it? i'm wondering if i should keep the battery & motor, & just buy me an infineon controller or any other reputable controller.
elik1111   10 W
Post by elik1111 » Jan 16 2018 12:24am
The new controller they sent is not a sinwave but is good. I thought about getting a new controller but in my case since it's their bike, I will need to rewire and get a new LCD which is pretty expensive and require work. I will do it in a case this controller dies.
FlyingFinn   1 mW
Post by FlyingFinn » Jan 17 2018 7:15pm
elik1111 wrote:
Jan 16 2018 12:24am
Is this new controller a 100A or the same 80A? Because new kits are being sold with a 100A controller.
elik1111   10 W
Post by elik1111 » Jan 17 2018 8:13pm
They say it's a square wave 80A.
Is the new one a sin wave?
FlyingFinn   1 mW
Post by FlyingFinn » Jan 18 2018 12:43am
elik1111 wrote:
Jan 17 2018 8:13pm
They don’t say anything about it so most likely square. New kits from AliBaba are being sold with 100A controller.
FlyingFinn   1 mW
Post by FlyingFinn » Jan 18 2018 10:15pm
elik1111 wrote:
Jan 16 2018 12:24am
BTW can you hit 100kmh? 80A 72V controller doesn’t seem like much for a 8000w motor. Should I choose 19” or 21” moto rim?
elik1111   10 W
Post by elik1111 » Jan 19 2018 7:27am
With their heavy fat bike, 5000W, 80A controller and 100kg rider I hit 70km/h
elik1111   10 W
Post by elik1111 » May 06 2018 12:27pm
Does anybody have a Leili-TFT display for sale?
