Bigbikebob
While going at a fast speed and holding the throttle twisted I started to get cut off if I hit a bump or a pot hole.
If I try to rotate the throttle more nothing happens and only when I release the throttle completely and twist again the problem is solved until the next bump / pot hole.
I am not talking about the kind of power cut off that you get when the battery cuts off and you can actually feel the small vibration the moment it happens this cutoff is different and there is no vibration just a loss of reaction from the the controller to the the rotation of the throttle.
Does the reason are exposed wires momentary touching because of the force generated from hitting the bump and the controller doing the cut off because of the irregular signal?
