Is this a sine wave controller?
Grider   1 mW
Post by Grider » Dec 09 2017 9:33am
Check out the link. Is it a sine wave controller? It says it has 18 mosfets.
https://www.ebay.com/itm/48V-DC-1500W-B ... 0005.m1851
x.l.r.8   100 W
Re: Is this a sine wave controller?
Post by x.l.r.8 » Dec 09 2017 3:41pm
i have this controller. its 1500 watts peak, not a sine wave and probably only marginally better than a stock controller. there are some tried and tested controllers that can be had for cheaper and give the right power (sunwin and greentime for example) that will serve you far better.
Intelligence is distributed nearly evenly, with only the occasional concentration in one person. The total quantity of Intelligence is a constant: as more people come into being, fewer and fewer get a sufficient amount for themselves.
Some say this has already reached homeopathic levels.
Grider   1 mW
Post by Grider » Dec 09 2017 10:38pm
Ok then, well what about this one? Is this a sine wave controller?
https://www.ebay.com/itm/48V-1500W-Elec ... 0506.m3226
ferret   1 kW
Post by ferret » Dec 10 2017 3:48am
Girder,
unless a controller is specifically advertised as "Sine Wave", you can be 99.9% certain it is not.
If you describe what controller you are looking for, members will be happy to give recommendations. It will be faster than picking a controller and asking about it.
Avner.
Don't believe everything you think.
Cove GNG-Spot build thread
Astral Rune build thread
Grider   1 mW
Post by Grider » Dec 12 2017 12:11pm
Yes, I'm looking for the best ecomical 48v sine wave controller, maybe programmable. There must be alternatives to the pricey Sabvoton, Phaserunner, and Kelly controllers which run from $200 to $300 USD. The lowest price one ive came across was the E.R.T. controller for around $120. This upgrade would be for fun, nothing serious, to gain a little bit more performance and efficiency from the square wave controller that came with the kit I purchased.
x.l.r.8   100 W
Post by x.l.r.8 » Dec 12 2017 10:15pm
$120 is pretty reasonable, in a few years this will be the standard but right now there are factories full of square wave controllers and they are the reason you have $40 controllers on ebay, but the real fact is the stock one its probably as good, these are cheap replacements rather than performance upgrades.
