Bafang G310 geared hub - 11:1 reduction ratio!!!
samsavvas   100 W
Re: Bafang G310 geared hub - 11:1 reduction ratio!!!
Post by samsavvas » Jan 29 2019 3:00am
I've just purchased a 310 from Grin unlaced. I plan to build it into a Sun Rhynolite 26" rim I have, 2 cross with some 14G plain gauge spokes I am able to source very cheaply from SJS Cycles (I have a frame-builder friend who can include them in his next order so I can save on postage).
Has anyone built one of these into a wheel yet?
Justin/GRIN recommend 13/14G Sapim Strong spokes because the 13G threads provide a stronger nipple engagement. However these are quite an extra cost. Has anyone used 14G plain gauge spokes? What's the general feeling - will they be OK? Should I use brass washers under the heads?
ta,
Sam.
amberwolf   100 GW
Post by amberwolf » Jan 29 2019 3:44am
samsavvas wrote:
Jan 29 2019 3:00am
Hmm...maybe it's because mine are for a small 20" wheel, but the 13/14 butted spokes I have from Grin are just single-butted, only 13g at teh spoke head, not the nipple end (which is just 14g).
Adamlivi   10 mW
Post by Adamlivi » Jan 29 2019 7:45am
Are you running a disc brake? The butted option will provide a some margin but more important will be the quality of the actual build in terms of strength and durability. I built up a g311 with a Rynolite with 13/14/13 spokes and quite happy but I would have used 14s if a cheaper option. I recommend you not use washers.
samsavvas   100 W
Post by samsavvas » Mar 10 2019 5:30am
Thanks Adam, what's the problem with using washers? Sam
Jil   100 W
Post by Jil » May 04 2019 5:19pm
G310 installed on my Surly Krampus, thanks Grin for the kit :)
Battery 52V/10.5+7Ah, rims Ryde Andra 40, tires Surly Extraterrestrial.
After a first 15kms ride, this new version of my e-Krampus is muuuch better for my use (mainly road) than the previous one with BBS01 and 29+ tires.
Before :
After :
My bike : Surly "eKrampus" with GMAC 8T, Phaserunner and 20 Ah/52 V Li-ion battery.
lightrush   10 W
Post by lightrush » May 04 2019 9:23pm
Very nice. You should get a Sempu T4.3 for torque sensing.
Jil   100 W
Post by Jil » May 05 2019 2:55am
Thanks ;)
I'm used to the basic PAS, that's why I choosed it, but I think my next try will be a torque sensor.
tomjasz   10 GW
Post by tomjasz » May 05 2019 2:17pm
Nice sweet build! And stealthy too. Well done!
Jil   100 W
Post by Jil » May 05 2019 3:39pm
Thanks Tomjasz :)
Yes this motor is very stealthy (despite its 6-700W of max power), it's even more visible on the other side :
lightrush   10 W
Post by lightrush » May 05 2019 3:53pm
Watch out with the max power. 700W-1000W is entering the gear failure risk territory. Use slow up ramps and install a temperature sensor if you can. I'm yet to do the latter myself.
Jil   100 W
Post by Jil » May 05 2019 5:54pm
Indeed I'm using the 500-700W setup only at speed higher than 30 kph in order to limit the torque on the gears.
By the way, what is the maximum power that can be used safely on this motor during city commuting, with many
stop and go ?
Jil   100 W
Post by Jil » May 05 2019 6:04pm
I found my answer here: https://www.ebikes.ca/product-info/geared.html
"The nominal power rating of 250W from Bafang doesn't mean a whole lot. These motors can put out 30 Nm of torque continuously and upwards of 40-45 Nm for short times without overheating. At higher speeds (like 40 kph) this translates into a solid 600-700 watt continuous power levels, while the corresponding power at lower speeds is more like 200-300 watts. Usage beyond 50-60 Nm is not recommended as there is real risk of stripping the gears."
lightrush   10 W
Post by lightrush » May 05 2019 7:08pm
Jil wrote:
May 05 2019 5:54pm
stop and go ?
I can tell you that running it with a lot of stop and go at 1kW with sharp throttle ramps and no regards to temperature has resulted in melted gears in about 1000km. The same person who blew the gears is now running it limited at 700W with slower ramps and regreased very well hasn't had a problem again. I think he's well over the 1K km mark with the new gears. I'll be installing a temperature sensor on mine for monitoring and limiting. But it seems if you aren't going over 700W and your throttle ramps are low and you're doing leg work during starts, you should be fine.
Jil   100 W
Post by Jil » May 06 2019 5:52am
Thanks :thumb:
Jil   100 W
Post by Jil » May 12 2019 3:22am
Do you know if regen is possible with the G310 (and more genrally with reducted motors) ?
1N4001   100 W
Post by 1N4001 » May 12 2019 4:42am
It's not, due to the freewheel/clutch. If you want to do regen in a geared motor, you can either buy a clutchless one (such as this) or weld the clutch fixed in your G310.
justin_le   10 MW
Post by justin_le » May 28 2019 10:45pm
1N4001 wrote:
May 12 2019 4:42am
Actually, while that advice holds with most geared hub motors, it wouldn't be advisable on the G310 because of the helical cut sun gear. That puts an axial thrust component on the planet gears and the motor rotor which is absorbed by thrust bearings, but those thrust bearings are only installed on one side.
If you run it with a locked clutch and did regen, then the planet gears and rotor would get pushed in the other direction and could scrape against a surface that wasn't meant for that.
I mean I haven't tried it yet, but first reflection is that this would be a real risk unless you went and modified the insides to have thrust bearings on both sides of the planet gears and rotor.
Previously competed in the Suntrip race on a back to back tandem solar powered row/cycle trike. 550 watt solar roof, dual Grin All Axle hub motors, dual Phaserunner controllers, 12 LiGo batteries, and a whole wack of gear.
Now back in Vancouver learning to be a dad with my Big Dummy Frame (yes This One, thanks ES!) with GMAC 10T rear hub motor, Phaserunner controller, and 52V 19Ah EM3EV pack
My website: http://www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs, which are disabled
qwerkus   1 kW
Post by qwerkus » May 29 2019 11:27am
justin_le wrote:
May 28 2019 10:45pm
That's an awesome picture - thanks. Always wondered how those cheap "thrust bearings" look like. I'm also interested in regen and quite crafty. Do you think the pinions offer enough space on the secondary reduction side for a second axial load bearing. Looks pretty tight to me.
justin_le   10 MW
Post by justin_le » May 29 2019 3:02pm
qwerkus wrote:
May 29 2019 11:27am
Here's what they look like installed behind the planet gears, it's pretty slick since they fit inside a recess in the gear casting and don't add any width to to the gear assembly.
It is tight, and there isn't the same amount of space for a thrust beraing washer like there is on the other half of the gear. Assuming though that the ball bearings inside the gears bottom out against a lip, then you could in principle replace the 3 bearings here with angular contact bearings that have the same geometry but are designed to take a thrust load as well.
That would be the neatest solution. Then you should just need to add a small thrust bearing on the end of the helical sun gear to take the thrust loading on the rotor. I've taken apart another small geared motor with helical gears which had one of these on it:
So that's definitely doable too. Unfortunately Bafang isn't a company that is game for upgrade requests or small mods like this unless you are talking orders in the 5K-10K volumes at least, so until then any regen ona G310/G311 motor would have to be a DIY affair.
I do have lots of random miscellaneous G310/311 motor parts around if someone wanted to carry the torch and try this out!
qwerkus   1 kW
Post by qwerkus » May 30 2019 4:41am
justin_le wrote:
May 29 2019 3:02pm
Awesome reply. Thanks a lot for the details. I'm in - though I doubt the small g311 can handle a lot of regen heat, even with ATF cooling, so I'm going for the larger brother g360.500... as soon as I find a seller for it! Will keep you updated. The only question remaining is how to lock the one way bearing which acts as a clutch, but I'm confident a simple solution will come up.
justin_le   10 MW
Post by justin_le » May 30 2019 2:00pm
qwerkus wrote:
May 30 2019 4:41am
I'll be posting my disassembly analysis and test results on the G360 on this thread here later today
https://endless-sphere.com/forums/viewt ... 2&t=100461
In the end we'll probably not be carrying and offering this hub motor for reasons that I'll be outlining there. It took us about 6 months to get a sample from Bafang so I gather there could have been supply or mfg. issues that they needed to sort out.
Most people just degrease and give it a few zaps with an arc welder, but if you don't have access to welding gear then drilling and inserting screws or dowel pins does the trick too. Just beware that it's usually hardened steel and the domain for cobalt bits and not your typical cheapo TiN coated hardware store stuff.
Reason: spellilng
qwerkus   1 kW
Post by qwerkus » May 30 2019 3:36pm
justin_le wrote:
May 30 2019 2:00pm
Yes, saw your other thread. Fascinating work - thank you. I also kindof figured out what you take on the g360 will be :)
I've been trying to get another sample of a high power dual geared hub from quarks: https://www.alibaba.com/product-detail/ ... 3e5fIb7dUj
If the picture is an accurate description of the motor, it should be pretty torquy, or so I gather from the number of poles and the rotor/stator width. They told me 800W is the max. power the nylon pinion would handle. Unfortunately, they also don't seem to be open to deal with small timers like myself,so getting a sample will be tricky.
Jil   100 W
Post by Jil » Jul 18 2019 2:21pm
Quick update, I have made more than 2000 kms with my G310 in 2.5 months, it works flawlessly.
I use it at 450 W in town (or when I restart after a stop), 675W on roads (only above 20 kph), with 14S battery, up to now it handles well these settings.
neptronix   100 GW
Post by neptronix » Jul 18 2019 3:29pm
Jil wrote:
Jul 18 2019 2:21pm
Thanks for the long-ish term report!
I have a G310 but i still haven't fired it up :oops:
qwerkus wrote:
May 30 2019 3:36pm
From the motor spec sheet, it doesn't look like you're missing much. That's a lower continuous power rating than the MAC, and if we think of motors in terms of 'power per pound', it's right on par with the MAC.. and this makes me wonder exactly what went wrong with the design, or if we're looking at heating being a limiting factor..
I like geared motors a lot and wouldn't touch it.
Jil   100 W
Post by Jil » Jul 29 2019 8:09am
Hi,
Do you know if it's possible to replace the standard freewheel hub of the G310 by a Sram XD ?
Indeed I would like to mount a 10/42 or 9/46 (11 speeds) cassette, and it seems to be impossible with the current freewheel.
The resason for my question is that I have mounted the largest chainring possible (36 teeth) on my Surly Krampus frame, and my top speed is limited by my 11/46 Shimano cassette.
EDIT : it's impossible to install a SRAM XD hub on the G310.
I managed instead to install a 38T chainring with a boost Sram GX crankset, and it is perfect with my 29x2.5" tires : at 45 kph - my max speed on flat terrain - with 38x11ratio I pedal at 95 rpm.
