Carbon Frame and BBSHD
barbs00
Post by barbs00 » Jan 10, 2018 5:16 pm
Hi All,
I have the chance to get a really cheap Giant anthem advanced 2016 - Carbon frame bike.
I would like to add my BBSHD motor to this frame.
Are there any issues using a carbon frame with a BBSHD mid drive?
Cheers
amberwolf
Re: Carbon Frame and BBSHD
Post by amberwolf » Jan 11, 2018 2:18 am
There's been some discussion of BBS* and carbon frames; in case they're useful, here's a few threads with those in the title (there's probably other individual posts or threads without that in the title that have info too)
https://endless-sphere.com/forums/searc ... mit=Search
barbs00
Post by barbs00 » Jan 11, 2018 7:22 am
Thanks Amberwolf.
I went out to see the bike today and unfortunately the bottom bracket is around 90mm and the BBSHD I wanted to fit (already have it) is the standard 68-73mm version. Damn!
I am guessing the answer is no....but is there any way to make this fit without a ridiculous amount of effort? Anyone sell something that may help?
Cheers
fechter
Post by fechter » Jan 11, 2018 10:46 am
They make a 100mm BBSHD for fat bikes. This could work with a spacer.
barbs00
Post by barbs00 » Jan 12, 2018 3:57 am
Yes that might work but unfortunately I already have a standard size BBSHD motor I wanted to use.... :x
Are the small teeth/grooves of the BBSHD that bite into the bottom bracket likely to damage a carbon frame?
Someone told me it could crack the frame but the teeth seem so small that I can't see this happening? Then again I have been wrong before :D
Epyon
1 W
1 W
Post by Epyon » Jan 12, 2018 8:52 am
Any carbon frame with a threaded BB is going to have an aluminum insert, so no problem. A press-fit frame may not, but you'd have to use an adapter anyways.
SlowCo
Post by SlowCo » Jan 12, 2018 10:21 am
Be careful as some carbon frames have a bottom bracket that is too thick in material for the BBSHD to fit. See this thread:
https://endless-sphere.com/forums/viewt ... &p=1127215
And the clearance of the BBSHD:
BBSHD clearance for BB.jpg (123.83 KiB) Viewed 381 times
barbs00
Post by barbs00 » Jan 13, 2018 5:38 am
Very helpful! Thanks.
I didn't think of that but it makes sense as Carbon BB are thicker than Alloy
