Strange problem with my bike. Controller?
Matell
10 µW
I have a Luna 1000w kit with about 40 miles on it. Today when riding, it stopped working. The throttle stopped working and the rear wheel suddenly had resistance. The battery is full and there doesn't appear to be any cut wires or loose connections. The speedometer still gets power and lights up. When I twist the throttle the bike jerks forward for a second and there is a single clunk sound in the motor. If I try to just roll the bike forward there is a lot of resistance and vibration from the motor. If I disconnect the motor from the controller the wheel rolls freely. If I connect it back to the controller (even with the battery disconnected) it has resistance and becomes jerky again. Any ideas what this could be? A loose connection inside the wheel?
Controller probably has blown FETs, shorted internally. http://ebikes.ca has a Learn page with Troubleshooting info on how to test for those.
The wheel rolling fine without ocntroller means wheel is fine, and so is wiring up to the point it connects to controller.
Classic symptoms of blown controller. short in a blown fet. Hopefully they will send you a new one.
