I have a motor problem can not run on controller
peleap
i have motor no hall sensor wire . when i connect motor with controller sine wave hall sensor . motor not work
้how to can convert the controller without hall sensor.
thank you
To run a motor that has no Hall sensors, you must use a controller made for sensorless operation.
You can run a motor that has sensors with a sensorless controller, but not the other way around.
