Help needed Motor does not run
CrawlingWhisper   10 mW
Post by CrawlingWhisper » Feb 10 2018 11:45am
Hello,
I'm attempting my first E-Bike build and just finished the wiring. Unfortunately not everything works right away. I hooked up all the connectors to my Infineon Controller, the switch to power the system up works, as I can tell by the CA also working. When I turn the throttle the motor does not respond. I use these components:
https://em3ev.com/shop/9-fet-irfb3077-i ... ontroller/
https://em3ev.com/shop/half-twist-throt ... ed-cruise/
Mac 10T (cassette)
I have a multimeter and this tool:
https://em3ev.com/shop/ebike-tester/
How should I proceed, to make everything work ?
Thanks
Felix
Jon NCal   1 kW
Re: Help needed Motor does not run
Post by Jon NCal » Feb 10 2018 1:43pm
Are you using the CA to control the throttle, or direct throttle to controller?
brumbrum   100 kW
Post by brumbrum » Feb 10 2018 3:18pm
Unplug the CA and see if you get power. Then you know it is to do with the CA settings. Not much help, but an easy place to start
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
Post by CrawlingWhisper » Feb 10 2018 7:56pm
It's directly pluged to the controller.
Thanks, will try.
fechter   100 GW
Post by fechter » Feb 10 2018 8:41pm
There are several things that can make it not run.
Brake switch activated
Hall sensors signal invalid
Battery voltage too low
Throttle signal bad
And probably a few more, but you can eliminate these one by one with testing. I would try unplugging the brake switch wires too, as these are not needed to make the motor run.
Minimum battery voltage is programmed into the controller.
Post by CrawlingWhisper » Feb 11 2018 11:37am
Thanks, that was it. I thoughtlessly mounted the brake sensor without mounting the magnet. :D
