Hi guys could do with a little help.
I am trying to use limits on the cycle analyst v3 dps
But it don't seem to be working.
I am seeing the limit flags flash on the ca when limiting and I am also seeing the tho voltage come down in voltage to override my throttle but it does not seem to have an affect.
It's is like the controller is ignoring the throttle out from the cycle analyst
Setup
Cav3
Ca3 3 pos switch (presets)
Xie chang/infinion 18fet (still confused what these are called my first ebike)
Mxus 3k 4t
100v 24s battery
Wiring scheme is option c from the ca manual
My throttle is wired straight to 18fet controller
Ca direct plug plugged to 18fet controller
Settings
Ca3 dps (modified tho moved to thd)
Throttle out control mode off wot
Throttle out voltage 1.2v to 3.8v
Xpd infineon 4 settings
Block time/overcurrent detection tried 0 and 0.1
Things I noticed when briefly testing
Limiting not working
Not getting even half the power I had before trying this setup or my 3 speed switch(infinion) is no longer working and it's stuck in pos 2 (low power)
I did not have my speed sensor on the fork while testing not sure if this would make a difference
The infinion 3 speed switch is just there from old setup i won't be keeping it if I get this sorted
Possible theory. I messed up soldering the green wire tho to thd(I think I can test this with a voltmeter at the ca direct plug)
Any help would be much appreciated thanks guys
Setup
Cav3
Mxus 3k 4t
100v 24s battery
Settings
