Xiongda YTW-06 mini hub motor
qwerkus   100 W
Re: Xiongda YTW-06 mini hub motor
Post by qwerkus » Jul 20 2018 4:13pm
zro-1 wrote:
Jul 06 2018 12:19am
Wow! That explains so much. I was wondering why the clutch remained so stiff. The fact that it is located on the rotor explains a lot.
Yeah - they actually call it a "one-way-bearing" to differenciate it from a regular clutch. Still the function remains the same, and I think it should be removed to allow for regen.
wturber   1 MW
Post by wturber » Jul 20 2018 4:19pm
qwerkus wrote:
Jul 20 2018 4:13pm
zro-1 wrote:
Jul 06 2018 12:19am
If it were that simple, one wonders why no manufacturers do this. I'm betting there's something we are missing. Like perhaps running backwards stresses the gears too much?
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
qwerkus   100 W
Post by qwerkus » Jul 20 2018 4:53pm
wturber wrote:
Jul 20 2018 4:19pm
Don't think that's the issue. The YTW-06 uses straight and helical gears, which both work the same way in either direction. I think it's rather about preventing overheating during regen (even now, the motor runs quite hot) and cost cutting: regen = you need another controller.
lightrush   10 W
Post by lightrush » Jul 27 2018 9:31pm
I got the Bafang G310 and can confirm that the clutch is between the ring gear and the outer shell. A friend with identical G310 blew the gears in 1000 km at 1 KW (20 A at 52V). We just replaced them, filled it with grease and limited it to 700 W. We'll see how long it lasts. I'm really curious to know if the YTW-06's gears can handle 20 A without melting.
zro-1   1 kW
Post by zro-1 » Aug 01 2018 11:53pm
I've been running my YTW-06 at a max of 54.6V, 20A for about 90 days without issue.
I need to point out (again) that I don't run the motor at that level all the time though. I use a Phaserunner which is a FOC, so the amps delivered are based on throttle. Most of the time I run at 30% throttle which is just 6 amps, and occasionally run at 70% throttle which is 14 amps. I only push the motor to 20 amps when I'm tackling a really hard hill and that's only for about a minute. The motor has been perfect at these power levels without any issue.
If you have a FOC and can control the amps going into the motor you shouldn't have any issues running this at as much as 20 amps. If you have a basic controller however, and you can't control the max amps, then I'd recommend setting a max current of at most 15 amps.
~01~
davideserin   1 W
Post by davideserin » Aug 02 2018 1:54am
Are you talking phase amps or battery amps?
zro-1   1 kW
Post by zro-1 » Aug 04 2018 11:32am
davideserin wrote:
Aug 02 2018 1:54am
Battery Amps.
I think max phase amps are set to 35, but I'm not 100% sure of that. It may be in one of my screenshots of phaserunner settings in my build thread.
~01~
neptronix   100 GW
Post by neptronix » Sep 09 2018 2:59pm
We've had a hellish summer here on the west half of the united states.. it's been hot, dry, polluted, and everything's been on fire. Riding a bike has been the last thing on my mind for months.. finally it's looking like we're in the clear.
So anyway.
There is a nut on the freewheel side that made my YTW-06 about 142mm wide or so. Take the nut off, and the motor is 135mm wide but a 7 speed freewheel extrudes past the axle and contacts the frame.. :evil:
And the axle has almost nothing for a shoulder, so forget just throwing a washer on there..
I have an aluminum road bike frame here, so i sure as hell am not going to stretch the drops far..
So being that the nut is maybe.. 8mm? i hit it with an angle grinder and hand file and took almost half the width off the nut.
Now i only need to bend my frame about 3-4mm or so to fit the dropout in.
It's off to get spoked and i'll have some feedback on it's power at low levels soonish.
Efficiency is everything :bolt:
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
The monster scooter: ? on a Cannondale Semi Recumbent.
davideserin   1 W
Post by davideserin » Sep 23 2018 6:51am
qwerkus wrote:
Jun 26 2018 5:41pm
If anyone is interested, there is a thread about this motor in a german forum, with many details, including internals:
It appears that the freewheel is actually located INSIDE THE ROTOR, which means when you're coasting, you're still driving the 2 stage reduction gears. Given that amount of drag already generated by this config, I'd suggest modifying the rotor to remove the freewheel, and try the motor with regen enabled. Should be doable - don't know why Xiongda told me it's impossible. Anyone up to it ?
Yes i'm interested! Do you have a link?
I'm also interested to have a go at doing Regen, but i'm not sure where to start with the motor. I've got a Phaserunner, so can set it up. Xiongda sent me a silver instead of black motor, so they sent another and i have a spare to play/experiment with.
I've also got two broken SWXH that i'm trying to make one good one out of. Burnt out the coil on one and the clutch is stuck on the other, but the clutches aren't coming off either of them.. if anyone has any tips! (i've sprayed WD40 overnight, taken off the snap ring and still no luck).
neptronix   100 GW
Post by neptronix » Oct 19 2018 4:42pm
FYI.. mine was defective in multiple ways, and opening it up cast some doubt on the integrity of the design in the first place. Currently in the middle of asking for a refund because i do not want another. It seized after 1 mile of riding unpowered.
Pictures and videos of the gore here:
viewtopic.php?f=30&t=96895
The gist of the thread is.. don't buy one :evil:
tiburon   1 µW
Post by tiburon » Nov 04 2018 9:22pm
anyone have working ytw 06 rear motor for sale? can also email me at dresaav@aol.com
tiburon   1 µW
Post by tiburon » Nov 07 2018 11:42am
there another motor similar to ytw 06. same weight. may be a better system. i dont know. i hear there issues with ytw 06. still interest in buy, ytw 06. anyone up. with regards to new motor, from alibaba ,only downside, u must buy 10 . i know im not up for that. for those that had no luck with the ytw 06, u may want to consider new motor. anyone? help with the purchase. i can use one. 9 buyers? 10 seperate orders might do the trick.
neptronix   100 GW
Post by neptronix » Nov 07 2018 11:56am
I was able to buy 1 unit through alibaba by sending a message.
Anyway it looks like they are willing to refund me on the motor they shipped that was constructed incorrectly..
I will update that thread i posted when i actually have something in my hands.
tiburon   1 µW
Post by tiburon » Nov 08 2018 9:40pm
for whatever reason , ytw 06 is no longer sell. so u guys was right afterall. motor got issues. either dat, or is out of business. dat must explain y no response to me messages. next best thing is yet to find out
neptronix   100 GW
Post by neptronix » Nov 08 2018 10:38pm
Oh really. When did you send them the messages?
I've been getting messages lately after threatening the paypal return. and they're claiming they'll send me a replacement motor in the coming days.
Cccc   1 µW
Post by Cccc » Nov 09 2018 2:01am
Bonnie no answering. Which email you use?
neptronix   100 GW
Post by neptronix » Nov 09 2018 9:40am
bonnie@xiongdamotor.com.cn
Shame that they've gone ghost on future sales.
massiveb   1 µW
Post by massiveb » Nov 12 2018 3:08am
Mine's getting delivered tomorrow, wish me luck :D
neptronix   100 GW
Post by neptronix » Dec 17 2018 11:27am
I got my replacement motor in.
Looks like the difference between the fast and slow motor is just a different gear ratio and slight difference in winding. The fast motor is marked as 9T; the slow motor is marked as an 8T.
Construction quality on my new motor is better, but some screws still have minor stripping going on. Seems that they need to start using the right screwdriver over there. Not promising.
One thing missing is the stator side supports. Both of my motors have 6 bolts compressing them down, but motors shipped to other customers have this aluminum tube stiffening up the space between both stator ends.
I'm a bit concerned about this, because the motor has a 2 piece axle.
qwerkus   100 W
Post by qwerkus » Dec 18 2018 1:49am
Actually shengyi has had similar motors for some years now. Their DWGQ1 is about the same size than the YTW-06, and their DWG12 more like the "new" bafang g311. Never tried one, but on the german forums, there are a bunch of huge shengyi fans, especially about the DWGX2, which comes with helical cut gears, and seems to be one of the best 3.2Kg motors out there. Funny how they also use lishui controllers...
neptronix   100 GW
Post by neptronix » Dec 20 2018 10:29am
I saw Shengyi motor at interbike and everything they had to offer was very unimpressive.
Looked at their page just now.. no dyno graphs.. no real motor details.. heavier weight for the power.. doesn't look good.
For me... no data, no buy.
neptronix   100 GW
Post by neptronix » Dec 20 2018 10:31am
More pics..
Xiongda sent me the tool to take off the motor case. It's 2 bolts threaded into a giant piece of metal.
And here are some measurements on the old stator after drilling out the stripped screws.
davideserin   1 W
Post by davideserin » May 12 2019 5:39pm
Hey, i'm about to get going on one of these using a KT controller. I've got the Regen working on the controller and wondering if anyone has figured out how to lock the clutch? I opened mine up and sealed it for oil filling and didn't properly check that myself. I'm going to be welding a Bafang G01 soon, so want to kill two birds with one stone if i can.
neptronix   100 GW
Post by neptronix » Jul 05 2019 10:36am
Dunno, but i'd stray away from this motor.
Bafang now has an equivalently sized motor with dual reduction... i'd pick that motor over this one, for sure.
I finally fired up the replacement motor Xiongda sent me, and holy crud does it sound like a hot mess.
At high RPM, it whirrs along like a bafang mid drive, but make nasty grinding sounds on the way up to top speed, given more than adequate peak power ( 15A )
When the little stator decelerates, it groans and makes 'i'm dying' noises, then when it freewheels, it sounds like a dragging brake.
I am going to pull mine apart and check for lack of lubrication, but things are not looking good..
