footbaldd
I was wondering how many of you guys are running watercooling on your drives? I have an ASI BAC2000 I will be using with a crystalite Crown 4080 with heatsinks and ferro fluid. I was looking at how much air flow there will be in the case, and decided to pick up some PC water cooling parts and give that a try on the drive in hope of being able to push some decent power without smoking it.
I got a radiator that is designed to fit two 120mm fans, a pump rated for almost 10 feet of head, and a pair of 40x80mm water jackets to mount the the plate of the ASI drive. I don't think I am going to add fans to the radiator, but it is more of an experiment at this point. I have a em3ev EEB frame and an planing on mounting the radiator on the frame behind the wheel, and making a composite fender to keep rocks and dirt from being slung in the radiator fins.
