You definitely don't want to remove it; that will kill the battery. Reducing it is the key.Andreas_t said:Thanx alot för the help guys! I found two Pictures of the gear and it seem like there is a cut off at 39 volts. Anyone can identify the controller and knows if it is possible to remove the cut off from this model?
billvon said:You definitely don't want to remove it; that will kill the battery. Reducing it is the key.Andreas_t said:Thanx alot för the help guys! I found two Pictures of the gear and it seem like there is a cut off at 39 volts. Anyone can identify the controller and knows if it is possible to remove the cut off from this model?
In general there will be a voltage divider going to either a comparator or an A/D input on a processor. To fix that you have to change the divider ratio so that the cutoff voltage decreases from about 39V to about 30V. Usually it's a one resistor change - but figuring out where the resistor is and what to change it to requires an EE background.
Yes. BMS is separate and should not be the primary means to discontinue discharge when the battery is dead.Andreas_t said:Thanx! Is this true even if there is a BMS on the battery, correct?
I am assuming you are swapping the battery completely (including the BMS) right? You're not just removing some cells from the top of an existing battery, are you? That would be bad.I sIf I manage to get the resistor changed to lower the cut off limit, will I face any other issues? Will the BMS be a problem?
Top wheel speed, assuming a "normal controller" i.e. no phase advance, will be reduced by 25%. Actual speed reduction will likely be less, since drag goes down at lower speeds.What will the difference in Power and speed be compared to a 48 volt system?
billvon said:Yes. BMS is separate and should not be the primary means to discontinue discharge when the battery is dead.Andreas_t said:Thanx! Is this true even if there is a BMS on the battery, correct?
OK, thanx!
Andreas_t said:Just to clarify the background of this project. I have an option to buy a 25km/h 250 W bike with a 36 volt battery at good price. I also have an option to buy the kit in the pic above at a good price. The kit is 48V 500W. This is why I am trying to figure out if there is a way to make this work out. The plan B would be to convert the fully functioning 36 volt battery to a 48 volt.
Regards!
eCue said:The Chinese kt controllers that comes packaged with the lcd5 or lcd3 display have adjustable voltage cut off points plus 30 more useful features. I use a 9 fret 36/48v 22A max version rated for the 351 - 500w motors.
