Need help with Sabvoton 72150
rastafhur   1 µW
Post by rastafhur » Mar 22 2018 8:45am
hi guys!
I´m building and EEB 72v 30ah bms 150a with a sabvoton 72150, my problem is, i can´t seem to power up the sabvoton.
I have a key switch connected to the + and the other end to the key connector on the sabvoton also the phase wires, 3 speed and throttle (Domino), tried to connect the + from sabvton to the key connector and nothing...
i think i got the throttle right,
Domino Sabvoton
Blue Orage
White Black
Black White/Grey
i have two gree one's, read somewhere that the green must be connected to 5v, so i connected the BLUE and GREEN together, is it ok?
What could be the problem? do i need to connect it to the pc first? also i got the usb dongle so i don't have to use pc, instead i will use an android phone (if that's possible to configure using android).
Hope you can help me out.
PS: the motor is a QS 205 V3, can´t wait to ride my bike, been waiting for 6 months (build)
PS2: think i found the problem, i was only getting 24V into the sabvton, it wasnt enough volts for it to power on.
evolutiongts   10 kW
Re: Need help with Sabvoton 72150
Post by evolutiongts » Mar 23 2018 1:15am
You should be a red/orange (ignition) coming from Sabvoton.
Connect a red wire (Battery position) to a switch and connect that to ignition. Turn on.
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
Mick48   1 mW
Post by Mick48 » Dec 21 2018 7:34am
Rastafhur:
Did you ever figure it out? I know its been 9 months since your last post but I was curious. BTW, nice bike!
