JanComputerman said:
I am running a RoboteQ 50 volt 150amp controller on a Chinese rear wheel hub motor direct drive with 35 amp phase limit
Unless that controller is unusual, then as AlanB noted it won't have any way of actually knowing what the phase current is, only the battery current, and then it "guesses" via math on the battery shunt reading what phase current *might* be.
My first Grinfineon 40amp controller and CA3 that arrived yesterday (yahoo!) powered up with a major throttle issue ... not to randomly working when going through the CA3 ...
If you haven't gone thru and completely configured the CA3, then it's behavior might not be anything like what you want until you do, as there are many interdependent settings in it. Go to the CA3 page on Grin's site, and follow the links there to the Teklektik UUG / etc, then follow all the steps in that guide to setting all of the menus up the way you want them to be, to ensure predictable behavior.
If you had Grin set it all up for you to start with then it'll at least have all the basic stuff done, but if not it'll all be at the defaults which may or may not be useful for you.
apparently the phase current is controlled by the throttle adjustments when passing through the CA3
No, it's not.
First, the Phase current isn't controlled at all in any of the Grinfineons I'm aware of--they simply dont' have a phase current sensor, so they don't even know what the phase current actually is, only the battery current.
Second, the CA has no control over anything other than what the throttle voltage is, and switching the ebrake line on and off. The only thing it knows about what the controller is doing is what the battery current is, via either the standalone shunt or the controller's shunt, in the battery negative wire. How the CA interprets that and then sends control signals via throttle and brake can be very simple or fairly complicated, depending on how you've setup the CA, but it still cant' control phase current as there's no mechanism to do so.
And I thought the controller power connectors we're not supposed to spark when connected to the battery? What's up with that?
Unless you have installed a precharge setup, or one comes preinstalled, then that's completely normal behavior. You can look up the many threads about it via "spark" or "precharge" to find ways to fix or minimize this.
