How to get more acceleration? (Mxus / Kelly / Multistar used)
VelluK   100 mW
Post by VelluK » May 09 2018 7:59am
I'm feeling that I don't get all acceleration from my bike what I could get. I would like to get the front wheel up :D
Motor is MXUS 3000 V3 3K Turbo, controller is Kelly KLS7230S and batteries are Multistar 6s 6600 mAh on 18s2p setup (totally 66,6 V and 13200 mAh).
Controller settings looks this:
https://i.imgur.com/RRFBfTr.png
What do you think about the settings, is there anything wrong? I have changed only Accel Time and Accel Release Time from 5 to 1. All other are default settings.
I know that Multistar batteries cannot give so much current that the manufacturer promises but what do you think could the batteries would be the reason for the bad acceleration? Theoretically batteries should give 132 A constant current (2 batteries in parallel * 10C * 6600 mAh) and 264 A in peak but if the real amps would like half of that it should still be enough for my bike.
All comments are more than welcome! And sorry about my English, hopefully it's good enough :D
Controller settings
Stealth ebike, hub motor MXUS V3 3K Turbo, controller Kelly KLS7230S, batteries Sony VTC5 20s6p (84V 15.6Ah), rear wheel moto 21"
amberwolf   100 GW
Re: How to get more acceleration? (Mxus / Kelly / Multistar used)
Post by amberwolf » May 09 2018 2:08pm
How much voltage sag is there when you accelerate? The more sag (the lower the voltage), the less total watts you get to the controller, so the less total power to the motor. IF theres a lot of sag, youd probably have to parallel more cells to fix it (or replace the battery with a better one with less sag).
I recommend going to the http://ebikes.ca/simulator and putting your setup into the simulator settings, to see what voltage and current would be required to get the torque you need to do what you want. You should first calculate that torque requirement based on your weight and your bikes configuration. Once you know how much torque it will take, and what voltage and/or current is needed to get that torque, you can then tweak your setup to give that.
Cant view the link to the settings. Recommend attaching the image directly to the post, or typing in what the settings are as text.
VelluK   100 mW
Post by VelluK » May 09 2018 3:05pm
Settings image attached to the original post.
Voltage sag is some volts, maybe 5 to 7. I have to check exact voltage sag.
Yeah, I think I have to get some more parallel batteries but before that I have to do some torque calculations.
Thanks!
VelluK   100 mW
Post by VelluK » May 12 2018 11:31am
Voltage drop on full acceleration is about 9 V (from 68 V to about 59). It's takes couple of seconds to get back to near 68 V. Is this 9 V drop too much or is this normal drop? What kind of voltage drops you have?
Do you have any ideas about the controller settings, is there something I have to change?
Thanks!
Punx0r   10 GW
Post by Punx0r » May 12 2018 3:42pm
I'm not familiar with Kelly controllers, but have you played with the "acceleration time" setting? It sounds like an acceleration ramp and might be limiting torque off the line that would help pop the front wheel up.
Otherwise, 50A of battery current seems a little weak - unless that greyed-out phase current setting really is delivering 380A at low speeds. Typical ratio of battery:phase current is 1:2 or 1:3.
Personally I'd set the battery current to 100A and the acceleration time to zero and see what happens :D but you might want to check that won't cause the Kelly to blow its guts out first. You'll likely soon need more battery in parallel though!
motomech   1 GW
1 GW
Post by motomech » May 12 2018 4:03pm
You are over-taxing the Multistar. It is designed for low discharge rates. If you are seein g more than a few Volts sag, you have the wrong batteries. You need at least 25C. I recommend Turingy.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/20Ah Multistar Lipo rear 5Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
viewtopic.php?f=3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
viewtopic.php?f=3&t=49691&p=1378484#p1378484
VelluK   100 mW
Post by VelluK » May 12 2018 4:11pm
Good point, the battery current seems to limit the power so I have to try that. I have not tried yet the Accel Time 0 but I should have to try that too.
Yeah I know that Multistars are not the best ones but so many on this forum uses them so they cannot be so bad if there is just several of them connected parallel.
I try these settings and probably I'm going to upgrade the battery pack from 18s2p to 18s4p.
Thanks for the good tips :)
motomech   1 GW
1 GW
Post by motomech » May 12 2018 8:22pm
It's not a case of the Multistars being "good" or "bad", they are designed for a specific application
I've been using Multistars since they came out and they are great for those of us who don't need high discharge rates. What we get are a smaller and lighter pack, low price and a low volatility factor.
On my 2WD, I have an 12S/1P Aux pack on the frt. motor and I can go back and forth between Multistars and Turnigy 20C's and I can feel the difference and they are only 20C!
W/ as much sag as you are getting now, adding capacity is not going to make much of a difference, so if you buy more, you will just be throwing good money after bad.
Motomech
eCue   10 kW
Post by eCue » May 12 2018 11:47pm
Make sure the connectors are well soldered in place as any weak connection will drop voltage adding to the batteries sag. After a ride feel them for heat also the less connectors inline the better.
With my 15 amp rated 48v 12ah pack limited to 14.8A I see a 2v drop on the flats with 3 to 4v sag in the wind or on hills so switch speed from 5 to 4 or 3 to keep sag at 2 or 3v. I use one xt60 connection and stock phase connectors
Have read 3 to 4 volts is normal over sagging kills them
Solar charge station on wheels join the Revolution
motomech   1 GW
1 GW
Post by motomech » May 13 2018 2:38am
On my Cutes running 20 Amp controllers, I barely get any sag at all, yet they don't have the "punch" of my Turnigy's. They stay about the same until they are discharged past halfway and then they start to drop off.
They are perfect on an "assist" bike where system power is not too important. In fact, lower power forces me to pedal :roll:
I like that they are avail. in so many shapes and sizes, as I tend to stuff my LiPoly into various frame bags.
If only Hobby KIng would get them back on sale again(And fix their website, it's awful).
Motomech
VelluK   100 mW
Post by VelluK » May 14 2018 2:16pm
After 30 min test drive the battery temperature was 42 C / 108 F. Controller was warm but not hot, maybe some degrees less than battery. Motor was so hot that it was not possible to touch by hand. Battery parallel connectors or any other connectors was not warm at all.
Accel Time setting was changed to 0 and Battery Current setting was changed to 100 A. Front wheel stayed on the road :)
Sounds that my batteries just cannot push my bike fast enought :)
eCue   10 kW
Post by eCue » May 15 2018 12:02pm
It sure does sound like you have the wrong batteries for the Motor. Curious how much sag you get at top speed ?
VelluK   100 mW
Post by VelluK » May 16 2018 10:18am
eCue wrote:
May 15 2018 12:02pm
About 1,5 - 2 volts. So not so much.
Motor was really hot after 30 min test drive. Controller cut the power to the motor couple of times. Motor temperature limit was set to 130 C degrees (266 F). It's interesting to know is this normal temperatuse for the Mxus V3 motor or is it too much for the motor?
eCue   10 kW
Post by eCue » May 16 2018 11:39am
I don't know your Motors top temp rating but likely the varnish will burn off first and short the windings if it overheats.
The windings are going to be warmer then the temp sensors reading so with it at 130 the windings could be 150c or higher which is approaching destruction...
With the multistar battery's I would limit the motors Amps for the acceleration. Also the heat is wasted energy
amberwolf   100 GW
Post by amberwolf » May 16 2018 2:08pm
VelluK   100 mW
Post by VelluK » May 16 2018 2:22pm
amberwolf wrote:
May 16 2018 2:08pm
are yo usure you have the rightphase/hall wiring combination betwen motor an dcontroller?
No I'm not sure. But the wiring is the only which got the motor rotating. Here is more about my previous problem: viewtopic.php?f=2&t=93785
New question, is it possible that there is several possible wirings which get the motor rotationg but some wirings get motor running hotter than some other wirings?
