Controller issues
Joely   100 µW
100 µW
Controller issues
Post by Joely » May 15 2018 3:38am
Hi all,
Ive recently put together a 72v 3000w kit on a kona five-o.
It was fairly straightforward and used torque arms both sides.
While the ride is fairly quick it's not been without its problems, not mechanically but on the electrics.
It started with a hall sensor problem, fortunately there is a spare connection so that sorted that out.
Then came a motor problem but pretty sure the controller was getting too hot.
Once cooled it was ok but didn't last long before it packed up altogether, no display and the wheel struggled to turn by hand.
I unplugged everything to free the wheel up so I could get it home but on plugging in the battery lead it was like reversing the red and black, big pop!
Im hoping the controller has caused this as it didn't like climbing hills anyway.
Could anyone recommend to me a good controller and LCD I could use, I'm told 18 mosfet upwards, to give the best performance?
I currently use a KT-lcd3 which I've not been that keen on as the power delivery isn't as instant off the twist grip as I'd like.
I have a brainpower controller on a 1000w kit which works beautifully.
I'm working towards fitting the 3000w kit into a full suspension bike once happy with it all.
Thanks for any help!
Martin (Devon, UK)
eee291   10 kW
Re: Controller issues
Post by eee291 » May 15 2018 2:02pm
You can increase/adjust your power settings
Joely   100 µW
100 µW
Post by Joely » May 16 2018 5:57am
Cheers for that, out of all the kits I've purchased, no one has given any more set up details other than how to bolt the wheel to the bike.
Out of a box the brainpower controller is the best I've used, like putting a turbo on your bike.
eee291   10 kW
Post by eee291 » May 16 2018 9:38am
Glad I could help.
I was gonna send you the PDF, but the translation is kinda bad.
