Hello guys,
greetings from Italy!
I'm writing here because i just finished banging my head to the wall
Working previous setup
BATTERY 16s5p - Samsung 25R
MOTOR Heinzmann Hub DirectPOwer
CONTROLLER Generic chinese 20A, working with prevous bafang BPM and the Heinzmann
THROTTLE 3-pin (standard? 0.8-3.6V output)
------ ...SO I DECIDED TO UPDRAGE -----
New controller from YuYang King
QSYK7250J with bluetooth
1) Can't get it connected with phone with the provided APP, because it crashes as soon as motor is connected, but found a Cyclone app that connect and works.
But the main problem is that the motor won't move an inch, when I give throttle
I've connected
Main + Battery
Main - Battery
Door Switch to + Battery
Throttle - With tested variable voltage on green signal cable
3 Motor phases (checked the junction with no resistance from controller to the motor plug
Also all Hall cables
At this point i can get the motor connected, it can also monitor speed if i run the wheel by hand!
But for the rest is very dead
My suspect is that there is another lock to jumper or something similar.
Any experience?
SENSORLESS MODE CONNECTION
SENSORED MODE CONNECTION
Here there is the manual
http://s000.tinyupload.com/?file_id=94718327357137741947
Plase any help will be appreciated.
I really don't want to belive they sent me a brick controller
Bye!
Mauro
I've connected
Main + Battery
Main - Battery
Any experience?
Bye!
Mauro
