Hi all,
I recently purchased a Mxus V3 motor, from what i read from "technical" information says max phase amp before overheating is 96A for 4t Mxus motor.
(https://endless-sphere.com/forums/viewtopic.php?f=2&t=92101)
On the other hand i've also seen many builds using much higher amperage with stock phase wires.. Should i be worried with the 4mm stock wires using something like 160A phase amps?
Give me your thoughts, thanks!
PS: if i should "upgrade" phase wires where could i find a nice tutorial and recommended wires?
