I found an abandoned, vandalized scooter in the gutter no battery or handlebars. It appears to be very new technology compared to other ebikes.
I connected a 36v power source to the controller. The wire harness that leads up to the throttle and on off panel has 4 wires, one of which is pack voltage. In previous troubleshooting of other e bikes I have found that the handlebar mounted screen sometimes has a 5 v regulator built in. The throttle frequently plugs into the handle bar screen, the screen into the controller. My question is how can I determine if the controller is waiting for a simple 5v throttle and or key on signal or if the controller is waiting for some sort of high speed network connection (can).
I could borrow an identical scooter to test the signals when the scooter is enabled and disabled.
Image of controller, vandalized frame below. My goal is to use the rear wheel and controller or to find a replacement controller that can run a very small hub motor in sensorless mode.
