Edge 1,500 with loose magnets and two broken need 10 magnets
999zip999   100 GW
Post by 999zip999 » Jun 10 2018 4:55pm
I open up my 1,500 edge motor to find all but three magnets did not move. Yes I did get it hot. Blue the halls still work. I'm taking out the and have broken two so far. It doesn't seam to have any glue. ??? Still I will need two or more magents. Plus what glue ? Two part epoxy ? The magnets are 35.00mm x 13.60mm x 3.00mm
P.S I'm up to 4 broken magnets. They can fly away land and brake.
spinningmagnets   100 GW
Re: Edge 1,500 with loose magnets and two broken
Post by spinningmagnets » Jun 11 2018 10:26am
"Very good magnet bonding epoxy" (bigmoose, Doctorbass)
viewtopic.php?t=27270
dogman dan   100 GW
Post by dogman dan » Jun 12 2018 6:26am
An epoxy they say you can fix an engine block will be high temp enough to glue back magnets, if you don't continue to cook off the motor. So JB weld, Pc7, etc is ok if you can't find really high temp epoxy.
999zip999   100 GW
Post by 999zip999 » Aug 22 2018 11:29am
Does anybody know where I can get 10 magnets.35.20mm x 13.50mm x 3.0mm thick ? Or does somebody have 35mm hub ring ??? Please help !
