Hi,
I've got a heating issue with a big electric "step like scooter" (I think this subforum is better for my technical questions).
I guess it is the controller : 52V 25A rated for a 1000W motor (and 52V 26AH battery)... but the controller is very small with only 6 mosfets. I openned it and there are small signs of overheating (I'm not a specialist)
Symptoms are :
cold start : 30% drop in speed/power (30km/h compared to 40+km/h on flat when everything was fine)
and a further progressive drop in speed on steep road until unbearable slow speed (10km/h).
stopping/cooling the scooter for a few minutes makes it works better again... for a while...
album of photos of the controller - I think the brown color on side of the green PCB in 2nd picture shows some overheating happened (I'm not talking about the resin on the back circuit in 4th picture).
My scooter seller is selling a replacement controller, and it seems to me to a high price (95$) and I fear the problem will come back.
My questions are :
Do the symptom match with a faulty controller ? Could it be the motor ? (shortcut in coils ?)
Should I search for a stronger controller (but I couldn't find any controller with same ratings and I'm not sure it will work with the throttle/meter) and space is limited in the deck of the scooter ?
Or should I buy the replacement ? if yes, can I improve the cooling someway to prevent another breakdown ?
Thanks a lot for your help.
Symptoms are :
My questions are :
