KT-LCD3 shows zero battery charge while voltage is 54.5
hardW   10 µW
10 µW
Post by hardW » Jun 14 2018 4:29am
Hi
I've got a following issue with my ebike: KT-LCD3 shows zero battery charge while voltage is 54.5 (according to it) and motor does not spin (both with throttle and assist). Controller is KT48ZWSRD-BSK11L, bettery Sinlion 48V 15.6Ah fully charged, motor is Bafang BF RMG06 48V500W(10). All the wiring seems to be intact. What can it be? Run out of ideas(
wturber   100 kW
Re: KT-LCD3 shows zero battery charge while voltage is 54.5
Post by wturber » Jun 14 2018 2:19pm
Sorry to ask the likely obvious question, but have you unplugged the battery, waited a bit, and the re-plugged it in?
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
hardW   10 µW
10 µW
Post by hardW » Jun 14 2018 2:29pm
Sure. It was first thing I've tried.
Also I want to mention that:
1) This bike was working fine for ~300Km
2) Last ride I've drained battery so that motor was not responding to both throttle and assist. But voltage was ok for display (and probably controller) to work. I've rode few miles on pedals. Then after ~10h I've plugged it in to charge.
amberwolf   100 GW
Post by amberwolf » Jun 15 2018 12:25am
Controller could have a problem sensing the voltage and/or sending the data to the LCD.
I have a Fusin controller / LCD (made by LiShui) set, where one controller works normally, and the other (using hte same LCD) doesn't send voltage or speed data to the LCD. The LCD does control the PAS modes/etc of the controller, either way, so I suspect something with the controller's transmit-data line, but never got to testing that (since the other controller works normally).
hardW   10 µW
10 µW
Post by hardW » Jun 15 2018 3:40am
Finally I've managed to shake controller and heard something loose inside it. It was resistor :shock:
Where was it soldered I can't yet figure out. I guess I'll need photos or schematics of this controller
eee291   10 kW
Post by eee291 » Jun 15 2018 4:21am
:arrow:
hardW   10 µW
10 µW
Post by hardW » Jun 15 2018 4:33am
Yeah those look most loose to me too. But they marked for different resistors - R63 and R64. Need to be sure.
eee291   10 kW
Post by eee291 » Jun 15 2018 4:35am
I just opened my Controller
I guess my controller is a newer version.
But when I look at your R63 solder pad it was definitely in there.
hardW   10 µW
10 µW
Post by hardW » Jun 15 2018 4:50am
Thanks. Our controllers have one in common: instead of two resistors (according to drawings), they have one. Guess this can be an issue, since two small resistors can have better cooling that one big. So I'm thinking about replacing it with two small. Unfortunatelly I don't see any other way not to make it happen again (unsoldering because of overheating).
eee291   10 kW
Post by eee291 » Jun 15 2018 5:01am
I don't think it overheated. If you look at mine, the resistor looks really badly soldered. I might apply more later.
docw009   10 kW
Post by docw009 » Jun 15 2018 11:07pm
Looks like you figured it out already, but here's my old PSWpower 20A controller.
Brown-black-black. What is that ..10 ohms?
