Looking at different battery configurations, I was wondering if anyone can confirm whether or not the 72xxx series Sabvoton controllers can run at a higher voltage than 90V? Specifically the 72150/72200 controllers, since they are the same afaik, with a firmware tweak.
I can build a pack up to 24S with my BMS, which would be nice, but at a full ~4.1V charge that is 98.4V, and I am assuming that Sabvoton put a pack limit at 90V because they are using 96V capacitors? But hopefully not, hopefully they are using something larger, like 108V.
Then I was thinking 22S, but that puts me at 90.2V, and if the Sabvoton controllers use firmware to detect this threshold, than I'm out of luck.
So with all that said, I am wondering if anyone here has gone above the 90V and it still works? Or will I need to contact QS or Sabvoton and see if I can get them to change it to 91V in firmware?
