VESC and PAS
Iippa   1 µW
VESC and PAS
Post by Iippa » Jun 20 2018 6:58am
Hi,
I'm using VESC 4.12 to drive an outrunner motor. Currently, the setup is working great as I'm driving the motor with a throttle. I would like to get it to work with a pedal assist sensor however. Has anyone configured VESC to operate motor directly with PAS? If so which pins should it be connected? I believe the PAS sensor outputs sort of PPM signal so it should be possible to make it work with VESC.
nieles   10 kW
Re: VESC and PAS
Post by nieles » Jun 20 2018 7:17am
easiest way would be with a Cycle Analyst V3
connect and configure the PAS on the Cycle analyst and connect the Throttle out to the VESC.
Iippa   1 µW
Re: VESC and PAS
Post by Iippa » Jun 20 2018 7:38am
Looks like that will do the job. Thanks nieles!
nieles   10 kW
Re: VESC and PAS
Post by nieles » Jun 20 2018 7:54am
check the VESC configuration tool just to make sure there are no pas options. (last time i checked there were not, but that`s a long time ago LOL)
or if you are comfortable writing firmware you could add it your self, but the Cycle analyst is by far the easiest option.
Addy   100 W
Re: VESC and PAS
Post by Addy » Jun 20 2018 1:42pm
Definitely check if you can do it directly with the VESC. If your PAS puts out an analog signal, the VESC should work fine with it, because you can configure the analog inputs to match whatever signal you want, as long as it's within the 0-3.3V range that VESC can read.
PPM signals may work as well because VESC supports PPM signals like you would get from hobby RC stuff.
Ecyclist   1 kW
Re: VESC and PAS
Post by Ecyclist » Oct 22 2018 11:15pm
Were you able to set up PAS on VESC?
I would like to do the same.
Can you post your findings?
Thanks a ton.
Don't expect from life to be easy and then it will be.
My builds:
Avian with hypocycloidal drive https://endless-sphere.com/forums/viewt ... 2#p1318056
2016 GNG extreme drive https://endless-sphere.com/forums/viewt ... 28&t=82252
Tom on 101   10 mW
Re: VESC and PAS
Post by Tom on 101 » Dec 17 2018 4:50pm
Yup I would love to see how this might be done. Has anyone made this work?
Dylandesmond   10 mW
Re: VESC and PAS
Post by Dylandesmond » Dec 25 2018 7:23am
Works with servo motor tester
amberwolf   100 GW
Re: VESC and PAS
Post by amberwolf » Dec 25 2018 10:39pm
Dylandesmond wrote:
Dec 25 2018 7:23am
Could you post the details on your setup that's using a servo motor tester to convert pedals to a PAS signal to the VESC?
Dylandesmond   10 mW
Re: VESC and PAS
Post by Dylandesmond » Jan 01 2019 9:42pm
Hobbyking sell them there are videos onyoutube
Dylandesmond   10 mW
Re: VESC and PAS
Post by Dylandesmond » Jan 01 2019 9:43pm
Dylandesmond   10 mW
Re: VESC and PAS
Post by Dylandesmond » Jan 01 2019 9:51pm
If its torque sensing that should be fine because itll do a analog voltage
otherwise its pulsing,,, if you're lucky it might match up, somehow i doubt it
ive only converted a torque sensing one, the servo tester just converts it into pulses for the esc to know what to do, i had mine setup as throttle and regen on the same throttle and the throttle would spring back to the middle, handy if you need to regen and hold both brake levers real tight for an emergency stop
thats one way,,,
