RageNR
- Joined
- May 23, 2016
- Messages
- 216
Alright, so there are many threads about wheel building, but I have yet to see any of them that pertain directly to building wheels for mid-drive setups. Most of them discuss building wheels with a hub motor.
With the high torque forces applied with some of the more powerful mid-drive kits, building a proper rear wheel to handle the stress seems quite important.
This is my first wheel build, but I have been planning to do this for several years now. Advice from seasoned wheel builders will be helpful and appreciated.
I will be sacrificing a bit of weight to build a stronger wheel. Here are the components I'm using:
- Alex DX32 rim, 26in, 36hole (ERD: 545.6mm)
- Novatec Hub, 36hole [not sure the M#] (Spoke hole size 2.3mm, O.L.D. 135mm, Spoke Circle L-62mm R-68mm, F.T.F. 58.1mm, L.C.F. 35.95mm, R.C.F. 22.15mm)
- DT Swiss spokes, preferably 2.0mm/14gauge (not sure which of their product lines to go with)
- Brass nipples (again, have not decided with product to go with yet)
I used prowheelbuilder.com to calculate the spokes. Someone check my math and make sure I got all of this right.
According to the calc, looks like I need 260mm spokes. That is using a 3 cross pattern.
Also, I am aware of the reputation and reliability of Novatec. I am limited on options due to having a 36hole rim, and the Novatec hub I will be using is one of their highest end products meant for enduro.
Here is the second half of this thread...
What would be most durable and capable of withstanding the twisting forces applied through the drivetrain into the wheel?
I think 3 cross pattern will be adequate, but how about the type of spokes?
Reading through Sheldon Brown's excellent site and info, he mentions that some builders opt to use stronger spokes on the drive/derailleur side. Considering the forces applied from the mid-drive, this seems like it would make even more sense in this application.
I am super excited to build my first wheel. Just need a little advice from the vets of this sport. Spoke recommendations?
