What are the chances that I have bought two bad controllers?
Hello
I am bench testing my new controller Model KT36/48ZWSRM-NBP03 and I can not get power to the motor
I have a freshly charged battery. 48V 12 amp. I do have power to the controller
I have the Power Plugged in RED BLACK to the battery properly
I have the Throttle hooked up to the controller Black Red Blue
MOTOR:
I have the Motor Hall large white "six lead" plug Black/White Red/Yellow/Green/Blue
I have all 3 stages wires plugged in Yellow Green Blue
I do not have the PAS plugged in
I do not have the 2 sets of Brake wires plugged in
I do not have the Instrument wires plugged in
I turn on my battery - I twist the throttle - the motor does not turn
I DO have an EBike Tester as you can see in the picture...
The throttle tests OK
The Motor tests ok in all stages as I turn the wheel.
When I plug the ebike tester to the controller ... and turn on the tester and battery, I do not get the 5v lighting up. And when I turn the throttle- nada
What is wrong? Do I need the PAS , Brake Wires / and Instrument plugged in for the motor to engage and turn?
Hello
MOTOR:
