DIY digital thermometer - sensor KTY 83
lukas999   10 W
Post by lukas999 » Jul 11 2018 6:03pm
Hey guys
any diy projects ?
looking for the solution to monitor my Mxus 3000 v 3
I don't want to open engine to change sensor
but I would like to hook in some module to see temperature of the engine
Luk
teklektik   10 GW
Re: DIY digital thermometer - sensor KTY 83
Post by teklektik » Jul 12 2018 8:28am
Well, the easy solution is get a CA3 and hook it up. This gets you automatic power rollback on overheating and all the other CA stuff.
But, a DIY approach is to get a programmable (y = mx +b) meter and set up the m and b coefficients for the KTY-83. You will still need to address a weatherproof case, DC/DC converter, mounting gizmo, etc.
A Sure Electronics ME-DV31423 Red LED 10V Multifunction Panel Meter should do the job. See:
https://www.parts-express.com/me-dv3142 ... r--320-536
You can pull the requisite parameters from the KTY-83 datasheet.
Teslanv (very reliable source) indicates that the Mxus3K uses a KTY-83/110.
(viewtopic.php?t=76133#p1162608)
Sure Red ME-SP037 Manual.pdf
(1.68 MiB) Downloaded 8 times
KTY83_SER.pdf
(54.36 KiB) Downloaded 10 times
lukas999   10 W
Post by lukas999 » Jul 12 2018 9:56am
teklektik wrote:
Jul 12 2018 8:28am
KTY83_SER.pdf
diy option sounds good to me
I won't be able to program it but if someone of You is willing to make it work I can pay !
PM me if You are interested
Luk
