Does anybody have experience pairing a sabvoton 72150 with a mxus 3k? I had my bike up and running for about 3 months using hall angle degree of 53 but I took it apart recently to change the connectors on the battery to XT90's however the controller lost its programming when I turned it back on. No matter how many times I run the angle test, it almost always gives me a "fail3" or "fail4" error. I've googled everything about these two errors and all suggestions just say "change the phase or whall combinations." I've tried all 36 combos and nothing runs smoothly. If I twist the throttle, the motor makes a loud clicking/banging noise. I can show a video if that would help. Even the hall angle test runs kind of funny. It jolts the wheel in one direction, spins it very slowly, jolts, then returns the "fail3" or "fail4." I've tested using both sets of hall sensors coming from the motor and nothing works. My old combo was swap green+yellow phase and hall but this seems to not make a difference.
Any help would be greatly appreciated, I feel like I'm running out of things to try. Thanks!
