I've recently purchased a cassette hub motor kit from Pasion Ebikes. I carefully read all the technical documents before purchasing and they specified that the hub's axle was 135mm between flat points each side. Perfect, as I measured my dropout gap to be exactly 135mm.
It's arrived and after putting on the cassette and measuring the distance, the size I've measured is at least 145mm with no washers and the gears rubbing on the frame. There's no way it will fit in my standard 135mm dropouts unless I bend the aluminium frame out of shape. I've contacted Pasion and they've told me that all hub motors are like this and that I should just bend the frame. Is this a normal size hub motor or are they having me on?
