EbobH
I have an old e-Moto Ridge I have been in the process of refurbishing. I have a S06S controller, a KT-LCD6 display, and the PAS I have is a KT-V12L.
For some of the settings I have no clue.
The manual is here http://www.szktdz.com/upload/file/20170925/20170925143050_36764.pdf
For P1, it says...
I have no idea how many rotor magnet pieces are inside the motor. Short of taking it apart and counting them, how important is it to get this accurate? It isn't clear to me what this does. Any place to start on typical number of magnets in an older 250W brushless direct drive hub motor?
For C1, it says ...
There is a table with two columns.One has the header "KUNTENG power assist sensors" while the other has "KUNTENG V12 power assist sensors".
In the "KUNTENG power assist sensors" column there are rows for ...
- Forward 5 Signal
-- 00 Standard
-- 01 Lower
-- 02 Lowest
- Forward 8 Signal
-- 00 Higher
-- 01 Standard
-- 02 Lower
- Forward 10 Signal
-- 00 Highest
-- 01 Higher
-- 02 Standard
For the "KUNTENG V12 power assist sensors" column, there are rows of ...
- reverse 6 signal
-- 05 Standard
-- 06 Lower
-- 07 Lowest
- reverse 10 signal
-- 05 Higher
-- 06 Standard
-- 07 Lower
- reverse 12 signal
-- 05 Highest
-- 06 Higher
-- 07 Standard
Am I correct to assume I should be using the "KUNTENG V12 power assist sensors" column? If so, then at least I know I am down to 05,06 or 07.
After choosing one of those, there is an additional parameter called "pedal speed pulse signal" setting. It shows up in the place where the cadence display is on the screen. There is a bolded comment that says ...
I was thinking that should be a 12 since I have a 12 sensor KT-V12L, but then why wouldn't that entire column be the same?
For P1, it says...
P1 = motor gear reduction ratio× number of rotor magnet pieces
For C1, it says ...
C1 is power-assist sensor and parameter select setting
- Forward 5 Signal
-- 00 Standard
-- 01 Lower
-- 02 Lowest
- Forward 8 Signal
-- 00 Higher
-- 01 Standard
-- 02 Lower
- Forward 10 Signal
-- 00 Highest
-- 01 Higher
-- 02 Standard
- reverse 6 signal
-- 05 Standard
-- 06 Lower
-- 07 Lowest
- reverse 10 signal
-- 05 Higher
-- 06 Standard
-- 07 Lower
- reverse 12 signal
-- 05 Highest
-- 06 Higher
-- 07 Standard
C1 additional parameters should be set according to the speed
pulse signal of the power assisted sensor, otherwise, the
displayed cadence numerical value is not accurate.
