Sabvoton slide-recharge problems
Newbeast
Hi!
im having problems with my sabvoton 72100, i have slide recharge on and it works great, but only when under 76v...
so if im above 76v i dont get any regen/braking effect from the motor, and i cant find anyway to set a different voltage in the settings.
am i missing something or am i stuck with this? :?
greatful for help :D
Your Sabvoton should regen up to 85V based on the seller.
Can you use the app to see if it throws an error when trying to regen?
Also what Battery are you using, and what is the overvoltage setting in the Controller set at?
Yes, the maximum limit for the regen braking is around 85V. However only if the parameter "over volt" is set to 96V (which is the max. possible for the unlocked Sabvoton which I have)
If "over volt" is set to something lower than this, max. regen voltage is about 10V lower than "over volt".
Try to set "over volt" to the maximum possible value and please let us know if it worked.
