multifrag
I have occasions when the hub motor would just drive into halt or start to jerk while at speed. I figured it was one of the hall sensor going bad. Checked if they react to magnet polarity and all of them do. Checked the wiring for broken or loose wire. All seem to work with out a problem. That leaves me thinking whether or not this is the controller acting up. My controller uses X8M06-C microcontroller. Don't think i can reflash it. Is there any other possible solutions to this problem or should I just buy a new controller?
P.S. The biggest pain in a*hole is that this problem is intermittent. Sometimes it can fix itself by just continuing to push the throttle, sometimes you need to stop and wait a little bit. I'll take it apart, do some continuity and power cycles and find nothing wrong. Assemble the bike back, ride 10 miles and it will happen again...
