Drunkskunk
We seem to have a lot of really intelegent people on the forum, and every one of you seems to have a unique prospective on things, and a unique field of expertise. So I think this would be the perfect forum for this kind of theroetical question.
To start off, lets say You have two motors, one has few windings, and operates at 24V and will do a max of 20mph. The other has many more windings, uses 48V, and will also do a max of 20mph. Which is more efficent in terms of watts used?
To rephrase it, whats better, low voltage, low winding, or high voltage, high winding motors for efficancy, with power output and speed being the same?
The two motors can be designed diffrently, as long a, for this argument, they are both brushless, and they both have the same power OUTPUT at 20mph, with 20mph being the max speed they can obtain at there respective voltage without any limiter. For ease of explination, both motors are either hub motors, or direct drive, with no difirential gearing.
Now, for a bonous question, which of these two motors would be most efficent at 50% of max speed?
