Best rear torque arm design/layout?
BAZ   100 µW
100 µW
Post by BAZ » Oct 07 2018 3:53pm
To beef up the dropouts on my ally frame, I've purchased a few off-the-shelf torque arms from ebay, but unfortunately the dropouts in my frame are shouldered in an unusual way and so all the ones i've tried (eyelet/jubilee clip) fail to line up in a good way.
So i've gone the homebrew torque arm route, I've got a bit of a background in 3D printing so have been designing (and test printing) something that can hopefully be laser cut out of steel plate in the next few weeks.
Unfortunately my frame has a lack of mounting holes leaving only the caliper IS points on one side and nothing on the geared side. I will most likely have to secure the arms to the frame through jubilee clips/hose clamps.
I've had a browse through the torque arm picture thread. I'm limited for tools and equipment and so the more complex axle clamping designs are out of my skillset. It seems some people set their torque arms to push the chainstay under acceleration and others mount them up against the seatstay with a clamp. With the seatstay option, the force seems to be transferred along the clamp to the frame, rather than directly like with the chainstay. This is then all reversed under regen braking, which I won't be running.
The issue I have is this, which torque plate setup is better? I should say I have a 1500w hub motor.
It is my understanding that solid mating with the axle is paramount, no point having a torque arm if it's not contacting the axle well.
With a chainstay torque arm, ensuring the axle is in full contact and tight against the torque arm will have to be done with rubber or metal shims between the torque arm and the chainstay. The accelerating force will then be transferred through the shims into the frame.
With the seatstay torque arm, using a clamp lets you pretension the arm to the axle, providing good axle contact. However this also means all the accelerating force will then be transferred through the clamp into the frame and they tend to be very thin metal.
I'm not sure which option is best.
So I've currently designed two arm options, one for each method i've spoken about. Is there a better solution? Are my designs way off?
Chainstay:
Seatstay:
p.s If any you know places in the UK that could laser/water cut my designs out of 5mm stainless let me know!
teklektik   10 GW
Re: Best rear torque arm design/layout?
Post by teklektik » Oct 07 2018 5:11pm
zzoing   10 kW
Post by zzoing » Oct 10 2018 5:43am
If you want to save time on machining metal, and you want a very tight fit to your custom frame, then you can use carbon fiber. Re-cycle one or two of the torque arms, and just mould the axial end into a carbon fiber blob that you wrap to the piece of the frame that you want.
Here's an idea for your bike:
1/ I would keep clear of the derailler and the disk brake bolts, I would instead use the yellow bar which is going like this / from the axle...
2/ I would carbon fiber some female bolts onto the / yellow bar aluminium, 1-2 of them, so you have an attachment point on there to fasten the torque arm. Job time: 30 minutes, drying time, 1 day. Others use hose locks, and there are discussions about if they hold well, probably they are the easiest way to go.
3/ I would wax and pvc tape all the surfaces and the female bolts and make a torque arm which fits just fine and which you can take on or off with a couple of bolts.
The carbon fiber is just fiber soaked in epoxy, bonded to sanded aluminium. it's somewhere in between wet string and plastascene.
I love my torque arm which i made from standard hardened carbon steel. It's 5-6mm thick and I can take the back wheel on and off without taking off the torque arm because it's a long slot. The axis slot is long and I can get the wheel out when the bike is upside down, but it's well fixed when it's riding.
tolkaNo   10 W
Post by tolkaNo » Oct 10 2018 7:02am
What program did you use to design the torque arms?
BAZ   100 µW
100 µW
Post by BAZ » Oct 10 2018 3:57pm
tolkaNo wrote:
Oct 10 2018 7:02am
Fusion 360, free yearly license to CAD enthusiasts.
zzoing wrote:
Oct 10 2018 5:43am
This is really interesting, i've never used carbon fibre as a material before. How easy is it to work with?
I'm currently modifying my design to match teklektik's suggestion, although still I think it requires a much more accurate modelling to ensure tension and mating on the axle vs a jubilee/clamp which you can tension after fitting correctly.
flat tire   100 kW
Post by flat tire » Oct 10 2018 4:00pm
The original design looks great.
Carbon torque arms might not be a great idea. Especially not made out of a mass of loose fiber.
Furthermore you shouldn't bond carbon directly to aluminum as stated above or you'll get galvanic corrosion. You need to use an intermediary like flox or fiberglass.
wturber   1 MW
Post by wturber » Oct 12 2018 2:55pm
From what I've read of Justin's testing, the main thing you want to do is used thick enough metal. Use 1/4" steel and you'll be fine. I used 1/4" mild steel for both convenience (can get it at any hardware store) and because I'd rather not have a harder steel possibly deform the threads on my motor axle. While it is nice to have a nice tight fit around the axle - especially if you are using regen braking - using a thick enough metal is probably more important since it not only provides more material to resist plastic deformation, but also spreads the load over a wider section of the axle.
I like Teklektik's modification to your brake side torque arm. Your cluster side torque arm design looks fine to me.
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
DanGT86   10 kW
Post by DanGT86 » Oct 12 2018 6:40pm
The brake flange is the best possible way to do it. That flange is capable of handling way more torque than your motor would ever output and connecting the axle to the brake flange would provide additional rigidity to the frame in general.
If you use regen at all then you want the tightest possible fit between the axle and the slot in the torque arm. Drive torque and regen are opposing directions so they have a rocking effect that will try to work the nut loose. For this reason I think the best option is a split clamping torque arm where a bolt squeezes the 2 pieces of metal around the axle. That is the very opposite of slop. The next best thing is the tightest possible fitment and a nordlock washer set under the nut. All that being said I have never actually seen a nut wiggle loose with off the shelf torque arms from ebikes.ca. I'm just lucky I guess. its pretty well documented.
If you are jobbing it out to a shop to laser or waterjet I would actually consider having them leave the distance between the flats about 0.1mm small and file it yourself for the tightest possible slip fit. Don't bother with stainless unless you really need the anti corrosion properties. It's not as strong as regular steel and terrible to work with if you want to drill or cut it later.
Nice work on the printed arms by the way. What an awesome way to prototype.
LockH   100 GW
Post by LockH » Oct 12 2018 6:54pm
DO regret very much anybuddy watt ignores history... including "torque arms":
http://www.ebikes.ca/product-info/torque-arms.html
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
John in CR   100 GW
Post by John in CR » Oct 12 2018 8:22pm
If you use regen braking, then torque arms that clamp onto the axle are the only acceptable type using anything above very modest power. All non-clamping types will eventually deform or worse, deform the axle, resulting in a loose fit and rocking motion of the axle in the dropout. Any exceptions require frequent inspection of axle nut tightness. I prefer never having to worry about such inspection, and just put air in the tires and remember to charge the battery.
markz   100 GW
Post by markz » Oct 12 2018 8:46pm
You asked for the best
Of course mine are
New Torque Arms.jpg (145.83 KiB) Viewed 980 times
999zip999   100 GW
Post by 999zip999 » Oct 13 2018 3:48pm
? Markz get out your 4in amgle grinder a plate of steel cut the axle slot tight and weld two nuts on then drill one . Insert bolt and Titan.
BAZ   100 µW
100 µW
Post by BAZ » Oct 14 2018 9:53am
Quick update to this. I've revised the caliper side arm to better match teklektik's recommendation. It's taken a few adjustments to get the hole to be a snug fit and align right but I think i'm pretty much there.
Good idea on undercutting the axle and filing it down to be tight. I've bought a small file set for this.
Just need to make the curve a bit less fat and then I can get it cut!
I'm still trying to find a lasercutter/watercutter in the UK that's willing to do such a small order/one offs. A few have got back to me but they have a minimum order of £150 or so :(
teklektik   10 GW
Post by teklektik » Oct 14 2018 11:20am
BAZ wrote:
Oct 14 2018 9:53am
Perhaps something similar to this using simpler geometries and keeping the lines parallel to the existing frame where possible for cosmetics.
BAZ wrote:
Oct 14 2018 9:53am
Big Blue Saw is popular in the US - they might be worth a look... (I've never used them myself, but...)
BAZ   100 µW
100 µW
Post by BAZ » Oct 24 2018 5:00am
Another update, got them cut out of 5mm steel for £15 a piece. Will need a bit of filing as I undersized the holes but looks great!
teklektik   10 GW
Post by teklektik » Oct 24 2018 7:53am
:thumb:
For other folks in a similar situation - who did those up for you?
zzoing   10 kW
Post by zzoing » Nov 09 2018 9:19am
Good information about Galvanic Corrosion and carbon fiber epoxy on aluminium. That's not a factor if you use a lock and key system to brace the aluminium. It is only a worry if you carbon fiber onto a flat surface like a bond, only as a glue. If you wrap CF around aluminium, it's set in stone.
For you guys who have awesome bikes that you ride until the frame fatigues, it's very useful. Just wrap CF around your old bike and you can recycle very expensive frames with a restricted stress zone or a bad weld. Because, if you braze aluminium welds, you have to temper the entire frame at 800 degrees for a day and at 400 for another day. That's how aluminium frames are prepared. Carbon fiber is a low temperature fix for aluminium frames.
When we can 3D print carbon fiber tools from the web, it can be the fastest way to customize mismatched torque arms. If you 3D print a mould and stuff it denseley with the epoxy, it can be fun too!
This is a 2 hour bike fix which is way over the top, it you could lift a car on it. download/file.php?id=206072&t=1
onemorejoltwarden   100 W
Post by onemorejoltwarden » Nov 09 2018 4:12pm
Torque arm fit /design question:
Cheapskate that I am I got some V_1 style NBPower torque arms from AMZ ($15 freeship)
They are not very snug on the 10mm axle flats. ~0.5mm slop
Do the Grin/EbikeCa ones fit better,snugger, as a rule?
Are generic copies of the early Grin TA's problematic?
I could put a small shim next to the flat, but that would be tacky,
or get a friend with a welder to put some slag in the hole and file it to fit.
"250 watt" 20"front Dahon with 11mm steel dropout slot, sensorless non regen
unk small controller that I doubt exceeds 20A
Thanks
"One more jolt, Warden, he's still twitching."
Golden motors 250w pedelec, Dahon/Aotema
iZipTrikosaurus, Cystalyte GT MTB
A a car hits man on an ebike every 10 minutes. We must find him, and get him off the street.
tolkaNo   10 W
Post by tolkaNo » Nov 12 2018 2:19am
What's the full process for designing something like this?
You sketch it out in cad then print it out on paper then keep printing on paper until its close, then plastic then finally water jet cut in steel?
Hardly anyone is doing custom bike specific torque arms like this and there's not many resources around that explains a noob like myself how to actually do it
