Xoc
I recently bought a kit from ebikes .ca:
- TDCM_IGH_305
- 25A Controller
- CA3
- 12Pole PAS
I'm having issues with it hunting to find a wattage.
I've set the autoPAS to give 300 Watts when activated, no change at different RPMs.
I have had to pull Wgain down to 5.00 so that hunting didn't cause the bike to be too jerky. Anything lower and it really takes a long time to get up to the power level.
At any speed below 23kph, I don't have any issue with watt hunting. As I go faster the watts swing farther below and above 300 the faster I go.
I've tested to see if it happens at autoPAS set to other powers (350, 400) and it does. It also happens at any pedal cadence with any amount of force that I put into the bike.
Any idea what I should be looking for? The power oscillations/Hunting are really annoying.
- TDCM_IGH_305
- 25A Controller
- CA3
- 12Pole PAS
