Winstonk24
Currently have a em3ev kit
52 v 26.6 ah triangle
40amp controller
Cycle anylist v3
Mac 10t
700c hybrid
Cruise speed of 27-30mph at 800-1000w flat ground. Holds 80C battery holds strong voltage. 48v on avg.
I recently spiced the wires where they go into the axle from twisting them from take the wheel on and off to replace inner tubes. I've also put about 5000miles give or take a thousand on the motor with 2000w peaks and 1000w cruise. I ride full throttle and only over heat from excessive full thottle launches. Holds about 80c cruising.
I want to replace the motor. I also want more top speed on the same battery I currently have.
Can this motor handle 8T with my setup for more top speed? Or is there another hub/controller combo that would give me a better top cruising speed with this battery.
40amp controller
Cycle anylist v3
Mac 10t
700c hybrid
