Nucular Electronics owner's thread (setup infos, FW updates, links etc.)
Offroader   100 MW
Re: Nucular Electronics owner's thread (setup infos, FW updates, links etc.)
Post by Offroader » Apr 06 2019 5:00pm
What will be the phase amp limit on this controller?
j bjork   10 kW
Post by j bjork » Apr 07 2019 4:35am
In the fist post you have the specifications for the different models:
https://endless-sphere.com/forums/viewt ... 31&t=75494
Stevebequik   1 mW
Post by Stevebequik » Apr 26 2019 5:49pm
We are nearly at the end of April, so assuming production controllers should be making their way to members by now.
Has anyone got updates?
Skaiwerd   100 W
Post by Skaiwerd » May 03 2019 12:30pm
Nope. In que for 12f for qsmotors 1000w mid motor. Hopefully soon.
litespeed   100 kW
Post by litespeed » May 04 2019 11:26am
Subscribed also.
Tom
SlowCo   100 kW
Post by SlowCo » May 05 2019 4:24am
devo1223   100 W
Post by devo1223 » Jun 18 2019 11:59am
Hey guys, I'm making all my connections for the first time and I just have the brake lever to connect. It only has two wires, do I connect it like a brake button?
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
devo1223   100 W
Post by devo1223 » Jun 18 2019 12:43pm
awesome! thanks for the quick reply
Merlin   10 MW
Post by Merlin » Jun 18 2019 3:47pm
do yourself a favor and install a simple throttle for ebrake. its way better as an on/off brake =)
devo1223   100 W
Post by devo1223 » Jun 20 2019 12:18pm
me again. Did the Auto-setup, I got it spinning but it is spinning slow at full throttle. I tried torque throttle and speed throttle with the same results. QS 1000 mid drive so set pair pole to 5. Controller mode is squarewave. It should be spinning at 2800rpm per my calculations. As I twist the throttle there does not seem to be much change in speed, in other words, the motor goes the same speed no matter what position the throttle is in.
20190619_210139 (600 x 450).jpg (86.69 KiB) Viewed 1352 times
20190619_205554 (600 x 450).jpg (48.45 KiB) Viewed 1352 times
20190619_205942 (600 x 450).jpg (43.44 KiB) Viewed 1352 times
20190619_210016 (600 x 450).jpg (50.37 KiB) Viewed 1352 times
20190619_210034 (600 x 450).jpg (54.1 KiB) Viewed 1352 times
VasiliSk   1 kW
Post by VasiliSk » Jun 20 2019 12:53pm
You have selected speed mode 1 where set 50% speed, i would not recommend to use square, better FOC
j bjork   10 kW
Post by j bjork » Jun 20 2019 1:09pm
To get the full (setup)speed with only a little throttle is expected in torque throttle mode, when you don´t have any load.
Because you don´t control speed (voltage), you control torque (amps). Very little amps are needed to run at full speed without load.
I am curios, are you one of the first to get your controller? :)
devo1223   100 W
Post by devo1223 » Jun 20 2019 1:11pm
Thanks! I was thinking I was in mode 1, but when I toggle to it and try to change it, it won't let me. The wiki says it defaults to mode 2 without a switch but yes it is clearly in mode 1. So do I need to connect a switch to change it from mode 1 to 2?
FOC is new and scary, is it as simple as changing the Control mode or is there something else I need to setup/know?
Merlin   10 MW
Post by Merlin » Jun 20 2019 1:34pm
j bjork wrote:
Jun 20 2019 1:09pm
no...there are some out there. looks like they are riding now only all time and dont strart posting :D
or maybe the sphere dies. who knows ;(
English subs available:
@devo,
in control:
Speed mode = Ref. speed
setup Reference speed = 100
100 means kph...if you have 50 on Mode 1 then you should reach 50kph.
with FOC settings you benefit some % of efficiency + sinewave (no square noise) and you can setup flux weaken to get more topspeed.
you can setup all 4 Buttons as you like. you can setup one button as a toggle between S1-S2-S3
or simple put S1 on Button, S2 on Button 2, s3 on Button 3
any maybe on Button 4 -> cruise.
j bjork   10 kW
Post by j bjork » Jun 20 2019 2:08pm
I suppose it means they are happy with it, and don´t really have any problems. Hopefully that is what it means :)
But strange anyway that they are not posting about how happy they are :?
If there where problems I guess they would post about that anyway..
Thanks for the nice video link, it looks to be working really nice :thumb:
Merlin   10 MW
Post by Merlin » Jun 20 2019 2:18pm
yea, iam pretty happy now =)
i hope statistic bugs will be fixed quick.
j bjork   10 kW
Post by j bjork » Jun 20 2019 2:54pm
Is it you in the clip?
I thought it was something you found on youtube :)
Merlin   10 MW
Post by Merlin » Jun 20 2019 3:43pm
yup its me :D
theres not much on YT about Nucular so i want to share more videos :D
yesterday was a hot day and iam still trying to heat that small thing up more then 50°c.
VasiliSk   1 kW
Post by VasiliSk » Jun 20 2019 3:47pm
Did i told about "full progress-bar challenge" ? winner gets 6F :lol:
You need to fill all progress bars with temperature, capacity and phase curent :D
Merlin   10 MW
Post by Merlin » Jun 20 2019 3:51pm
If motor and controller bar is full the capacity will be empty :p
agniusm   10 MW
Post by agniusm » Jun 20 2019 4:21pm
Asking for clarification. In the first post on the diagram it says psu or any dc source. I take it has to match pack voltage, not just any dc souce ?
devo1223   100 W
Post by devo1223 » Jun 20 2019 5:03pm
pretty sure the motor acts like a boost converter so you can have any voltage you want on the supply side. Does it act like a buck converter though? Can you supply voltage be higher than pack voltage?
Thanks you all your help guys. I guess I'm the first idiot to get a hold of one of these controllers :D
Merlin   10 MW
Post by Merlin » Jun 20 2019 6:13pm
any PSU will work. But iam sure it should not be higher then the pack voltage.
if the PSU voltage is very low you need more amps...more amps = more heat ...if motor is not a big brick like qs205 you have to check temps.
melting the motor is possible (i think) but vasily will explain.
some 12v server psu reach 70-80amps. your motor will heat up quick with no airflow...even a qs205 would start sweat =)
agniusm   10 MW
Post by agniusm » Jun 21 2019 10:52am
Would be great to have clarification on this. What will work and what most likely damage components. If it boost boosts voltage, and no exactly matched dc source is needed, that would be so awesome. Its a mess having all these different chargers. Wander if i have 2 of these, one running 48v another 72, would one 40V 20A psu do them both?
