Nucular Electronics owner's thread (setup infos, FW updates, links etc.)
PITMIX   100 W
Re: Nucular Electronics owner's thread (setup infos, FW updates, links etc.)
Post by PITMIX » Sep 01 2020 8:33am
Hi friends, i did the latest firmware update. The acceleration curve is very different although I kept the same settings. I really like how it works now, but I would like to know how to modify it? The starts are smoother and linear then the power delivers as if there was a Turbo. With the old firmware was abrupt at startup and then linear in acceleration.
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
PITMIX   100 W
Post by PITMIX » Sep 03 2020 3:30am
Its good ! :wink: I found it is in " control mode" there is a Throttle / brake curves adjustment and a lot of parameters to adjust it's great. :bigthumb: :D
electraflyit   10 W
Post by electraflyit » Sep 10 2020 1:09am
endrew wrote:
Jul 20 2020 7:33am
OK, I was wrong. When setting control mode to FOC, the motor stutters, see attached video:
https://youtu.be/I71vRFXVekE
Hi,
Did you find what the problem was when the motor stutters.
I have the same problem. Motor starts smoothly then stutters at about half speed.
MXUS 3k
Eddie
PITMIX   100 W
Post by PITMIX » Sep 10 2020 1:16am
it is necessary to reduce the setting of KPi to 100 instead of 500
endrew   10 W
Post by endrew » Sep 10 2020 3:02pm
electraflyit wrote:
Sep 10 2020 1:09am
endrew wrote:
Jul 20 2020 7:33am
Hi,
MXUS 3k
Eddie
It was the motor, Do not support FOC, probably hall sensors. Different motor works fine.
electraflyit   10 W
Post by electraflyit » Sep 11 2020 4:55pm
Vasily in the telegram forum advised on a PID value change that fixed my stuttering problem.
PITMIX   100 W
Post by PITMIX » Sep 12 2020 1:52am
yes which confirms what I say 2 messages above. No need to change the engine the Nucular adapts.
transposon   100 W
Post by transposon » Sep 15 2020 11:57am
I am about to place an order for a 6F controller. I had a few questions on what accessories I needed.
Is the "PWM IO/PAS wire" option only used for PAS? Or can it be used for other things?
Also, if I wanted to add front, rear, or turn signal lighting down the road, what options would I need? I assumed "Optical-isolated PWM driver". Would I ever need more than one of these addons?
Thanks.
VasiliSk   1 kW
Post by VasiliSk » Sep 15 2020 12:39pm
This cable for FAN / stoplight / PAS
What you described - you need uLight board.
transposon   100 W
Post by transposon » Sep 15 2020 12:57pm
VasiliSk wrote:
Sep 15 2020 12:39pm
Thanks for the reply. Do I need to get any options to make sure that uLight will work with my controller?
transposon   100 W
Post by transposon » Sep 16 2020 4:44pm
Is the "PWM IO/PAS wire" removable or is it soldered directly to the controller?
Also, is the CAN cable accessory just an extra replacement cable or is it soldered to the controller?
PITMIX   100 W
Post by PITMIX » Sep 16 2020 11:52pm
all cables are connected to jst-x on the motherboard.
Look at this :
https://drive.google.com/file/d/1KkEgWc ... sjpUQ/view
transposon   100 W
Post by transposon » Sep 20 2020 9:02pm
Did you guys have to split up the payment into 2 separate payments? One via paypal and one via cloud payment? Just wanted to make sure that this was legit.
Thanks.
Merlin   10 MW
Post by Merlin » Sep 20 2020 9:08pm
Doesn't sound right 🤔
Buyed above 20 controllers... All with sepa payment.
iacei   100 mW
Post by iacei » Sep 21 2020 6:22am
Hi Folks,
I currently have my ebike configured with a reention dp6 battery.
To power my bike I have to switch the battery one and then the Nuc.
Is there a way to configure the Nuc so that it powers on as soon as I start my battery?
j bjork   10 kW
Post by j bjork » Sep 21 2020 7:40am
Yes, I think you just set button "none" somewhere in the config.
I dont remember where, but it is probably in the manual.
I think I was able to find it just looking in the menus.
Tommm   100 kW
Post by Tommm » Sep 21 2020 7:56am
Do we have an idea where they are with the backlog?
gbeals   1 W
Post by gbeals » Oct 06 2020 9:36pm
If you folks could not get the Nucular Controller, what would have gone with? I've had the Votol and did not come with progressive regen and software was buggy with so many different versions to choose from as well.
I'm on the wait list for Nucular, but need to get something to pair up to my QS3kw motor. My Votol was 150 model and was plenty for that motor. Anything else on the market that is comparable?
PITMIX   100 W
Post by PITMIX » Oct 07 2020 12:17am
Kelly ... Sabvoton ... but the only one that compares to the Nucular is the Adaptto
andrewrich   1 mW
Post by andrewrich » Oct 08 2020 4:55pm
Hello all I was just wondering if I could get a little help. I just purchased a Nucular 6f and got it all set up today. I am using a cyclone 3000w motor and 72v battery. the problem is when I start to pull away the motor stutters, it only happens on very low throttle. is there some setting somewhere that will help me get rid of the stutter ? or has anyone got a cyclone 3000w already set up that I can have the config for ?. Any Help is greatly appreciated. Thanks.
John in CR   100 GW
Post by John in CR » Oct 08 2020 5:05pm
andrewrich wrote:
Oct 08 2020 4:55pm
It sounds like it may still be set to sensorless control. Set it to FOC and save.
andrewrich   1 mW
Post by andrewrich » Oct 08 2020 5:08pm
John in CR wrote:
Oct 08 2020 5:05pm
andrewrich wrote:
Oct 08 2020 4:55pm
its already in FOC Mode. any other ideas?
john61ct   100 GW
Post by john61ct » Oct 08 2020 11:32pm
gbeals wrote: something to pair up to my QS3kw motor
QS sells Kelly 7230S for up to 3kW I think
Anybody know if it does FOC?
PITMIX   100 W
Post by PITMIX » Oct 08 2020 11:51pm
@John61ct, Yes he's doing FOC.
@Andrewrich On PID regulator, You can decrease the KPi setting to 100.
Did you set the number of poles correctly ?
Did you do the last update?
