thunderstorm80
- Joined
- Mar 29, 2016
- Messages
- 383
Hi,
For short rides without pedaling, or long ones where you do most of the pedal work at slow speeds - the current Lithium batteries are enough.
But for very long ranges, or if you want to be able to cover a huge distance as a commuting route and do it fast (like 40-50kph), batteries are not enough anymore at the current technology. (the E-bike would have to get dangerously heavy)
I see a lot of portable generators for camping, but they are too powerful (2000W) and VERY HEAVY to be mounted on an E-bike.
Do you know of a small generator (that can produce about 700W) so that it won't be so heavy?
Or,
I know piston engines have a low power/weight ratio at those power magnitudes, but what about Wankel rotary motors?
I know Wankel didn't replaced the piston engine in our cars because it's not very good for engine-braking, but for the purpose I talk about where you need a constant torque and power - it could be very light and brilliant solution. (a fast revolving motor would need to output less torque and so it would be smaller - just like how Geared motors are smaller)
The last option I thought is about RC internal combustion motors for airplanes. Those spin at very high RPM's and so they can be small and elegant for the task. Do you know of a turn-key generator based on RC motor ?
Getting 220V 50Hz generator would be preferred, but DC voltages in the order of 80V as output should be fine too.
Or,
