wiring issues
rtb
I have replaced my controller but the wires don't quite match up can anyone tell me which wires to join to get power to the controller , i have attached an image of the new controller wiring diagram , its the anti theft part , my bike has a key switch with a yellow and red wire and this controller has a plug with red,green,blue
also my bike has an led display , i think i can bypass this to get me going but am not to sure
thank you
You should ask seller to get connection diagram and what to connect.
I think "electric door lock" might be same as power on and likely to be connected to battery plus. But if it is supposed to be connected to +5V instead and you connect full battery power then it will be smoke..
Ask them if it is +5v or full battery and what is power "ON" cable and how to connect anti theft wires.
Cheers
@tommycat: Ebrakes and ignition are not the same.. Maybe you meant the posts above in your thread?side note:I don't think it's correct to connect brake high to battery, it's a 5v logic signal, isn't it? will probably blow the controller if you do.
larsb said:
@tommycat: Ebrakes and ignition are not the same.. Maybe you linked the wrong post and meant the posts above in your thread?
I believe he was equating e-door lock to ignition in that post, which I believe to be the case, at least with my controller. Both 5V.
larsb said:
I've only had controllers with ignition switch at full battery voltage and i've had a few.
I think it's probably the cheapest solution to do it. Why do you say it's 5V? Want to bet me :D
Nope, I'll defer to your experience. The main point was the other post wasn't suggesting that ebrakes and ignition were the same, it was e-door lock and ignition.
This is excellent advice! Never start speculating until actual wiring diagrams are unavailible. Especially with maunufactures throwing different wire colors around.
larsb said:
... Maybe you meant the posts above in your thread?
Yes... I don't know why the link takes you to the bottom of the thread/ :?
Was not talking about the high brake signal at all...
TommyCat said:
Both your brake wire pairs need to be wired in parallel with your low E-Brake controller connection wires.
The Low E-brakes is a low voltage (5vdc) low amperage electronic circuit that is actuated by connecting the wires going to the E-brake connector together.
but if you were too... the high brake signals I am familiar with are 12vdc input for the high brake. (Kelly KLS) As sometimes one will connect it in with a 12vdc brake light power for actuation. :idea: :)
Exactly, and other similarities too.
I saw what you mean now that i'm on a computer, you wrote to connect the single yellow wire on the throttle keyswitch circuit to battery plus, and i saw the single yellow wire to brake high on the controller side.
Well well, it's friday night after all, we can't be intelligent all the time :D
