onemorejoltwarden
I have a Crystalyte hub that needed repair of insulating jacket on thru axle wire set
No increase in size of bundle but I am having trouble getting the covering collar over the axle and wire bundle
This collar freely rotated, but the wiring groove in axle is not deep enough or positioned to make this go back easily
( or as easily as it came off)
? Anybody have tricks for getting this collar back on? or any discussion of its function or even necessity?
The collar didn't rotate once the axle is tightened, but I can't say I noticed it much before the repair.
I could see it protecting the wires from abrasion but am unsure of its function and any issues in its installation.
? can I remove it or cut a channel through it?
Any pointers toward ways to best identify the motor?
It is a little less than 10" in diameter and has a 34mm width over the spoke flanges
and is probably about 4 years + old
I couldn't locate reassembly tips
