Rear hub motor with planetary gear but no clutch/freewheel -> How to upgrade
atala_bike   1 µW
Post by atala_bike » Jan 09 2019 1:18pm
Hi everybody,
I've been stumbling across this forum many times while looking for info's about ebikes and I must say this place is amazing, lots of usefull infos!
Recently I bought an Atala E-Light bike that I'm trying to restore as the previous owner didn't take a lot of care and many parts now need repairing.
The strange thing is that it has a rear hub motor but there is no clutch/freewheel inside, so the motor keeps spinning even when not in use. This add a lot of drag that my other ebike (an old frame I converted with an mxus kit) doesn't have. Therefore I was wondering if you could help me locate a compatible clutch/freewheel to install. Here are some pictures and the measures I've taken of all the components.
Gears 30t diameter 40mm height 10mm (or 12mm didn't wirte it down sorry)
Outside to outside of 2 gears 92mm
Metal plate diameter 74mm (where the gears are located)
Motor axle 12mm Woodruffkey 15mm
Total height 26mm (metal plate + gears)
Gears inner diameter (or external ball bearings diameter) 20mm
Inside hub diameter 112mm
Inside external gear diameter (the one fixed in the hub) 95mm
Thanks a lot in advance to everybody.
https://ibb.co/M5L2DJV
https://ibb.co/cXNNYnh
https://ibb.co/27jjfFk
https://ibb.co/RBfrJJT
https://ibb.co/cY0ZKhx
https://ibb.co/NSPc6GK
båndsei   1 µW
Re: Rear hub motor with planetary gear but no clutch/freewheel -> How to upgrade
Post by båndsei » Jan 16 2019 4:39pm
Here is a link Motor 26" přední 36V/250W 3pin/ovál SY736 stříbrný
It has no clutch freeweel. If it holds back try to disconnect the 3 wires from motor
Bernt
båndsei   1 µW
Post by båndsei » Jan 17 2019 3:44am
This link might be better:
https://www.google.dk/search?q=Motor+26 ... 7714154296
But it seems to be with 10mm axle
Bernt
