Advice? ebike battery to variable DC/DC step-down converter
spinningmagnets
Moderator
Staff member
Ft Riley, NE Kansas
I already have a robust potted DC/DC that takes 36V-60V and converts that to 12V for ebike lights, radio, etc...(search ebay for "golf cart DC/DC").
I have wanted a variable input/output DC/DC converter for a while (for a variety of projects). The push right now for me is that the kCap uses 6V-8V DC input to run. It is possible to use two kCaps to use a common 12V power supply, but I am exploring several alternatives. I have the part number for buying a used 6V supply, and that may eventually prove to be the best option for the kCap.
I could buy a half dozen cheap step-down DC/DC's to try out, but I don't know what to look for. It's not really the cost (these are all pretty cheap), but I hate waiting a long time for delivery, just to find out I bought the wrong thing.
The three possible inputs are a 12V car battery, 18V cordless tool battery, or a 48V/52V ebike battery, so that's the input range. I want a useful device for several reasons (my NiCD radio uses 4.8V, kCap uses 6V-8V, etc). I know that the narrower the performance profile, and the lower the amps needed, the smaller and cheaper the converter. Since this will be more of a "work-bench power supply" I don't need small size or max efficiency. A digital readout for the output is a plus, and CC/CV is useful if available.
12V-24V input = good
12V-60V input = best
Here's a current candidate. $16 10V-40V input, 2V-36V output
https://www.amazon.com/Aideepen-Con...i=B0747QDRW9&refRID=C1984MMD6JMH4N45D4HC&th=1
Google, Ebay, and Amazon give me a hundred results...I'm lost...
https://www.amazon.com/Converter-Adjustable-Regulator-Transformer-Stabilizer/dp/B07GGR1X8Q/ref=sr_1_16?ie=UTF8&qid=1547764822&sr=8-16&keywords=DC-DC+variable+step+down+converter
$40
https://www.amazon.com/Converter-DROK-Voltage-Regulator-10V-75V/dp/B071LGTTRN/ref=sr_1_8?ie=UTF8&qid=1547764745&sr=8-8&keywords=DC-DC+step+down+converter
$30
There are tons of options on Amazon.
