Best solder for shortening cables? (PAS, Motor etc)
Lovelock   10 W
Post by Lovelock » Jan 30 2019 4:18am
Hey,
New motor is being delivered next week and on of the issues I had on my last build was the extra length of wire I didn't need.
All of the cables; motor, PAS, display etc are going to be shortened to make for a nicer build.
I'm new to soldering, but watching some videos I don't think It'll be a problem.
However, is there a suggested solder to use for these cables? I could Google it but prefer actual thoughts from people who have used and done this.
Thanks. I'm from the UK, just going to be buying a soldering kit from Amazon with a two hand stand thing.
alfantastic   10 kW
Re: Best solder for shortening cables? (PAS, Motor etc)
Post by alfantastic » Jan 30 2019 4:36am
As a beginner to soldering, I would personally use a leaded 60/40 (60% tin, 40% lead) rosin core solder. It's easier to work with and a little more forgiving until you get the knack of soldering.
I personally use Stannol HS10 (60/40) rosin core solder (0.5mm)
Volt_Ampere   10 W
Post by Volt_Ampere » Jan 30 2019 9:15am
Do NOT use Lead Free solder. It's much harder to use. Also, never use plumbing solder or acid flux. You need a fairly high power iron to solder the heavy gauge wire we use. First make a good mechanical joint and then get it plenty hot when soldering. If the result isn't nice and shiny, you got a cold joint and you need to reheat and add more solder.
spinningmagnets   100 GW
Post by spinningmagnets » Jan 30 2019 9:34am
The small soldering irons with a "pencil tip" are used for adding or removing resistors or diodes (etc) on circuit boards. Many seem to be 40W.
I have had many soldering irons, but for ebike wire and connectors, the one I use the most is a cheap 100W unit I found in an art supply (the stained glass window building section), and it has a fat chisel tip. It works fast and confidently on wire as fat as 10-ga.
Copper is a good heat conductor, and as soon as a small tip touches the wire, the tip cools off too fast, but a fat tip has some thermal mass.
I have tried lead-free SAC305 (popular in industry), and all I can say about that is...when the government bans all lead-based solder, I will buy up a lifetime supply of 63/37, and even some 60/40. Having flux in the core of the solder is fine for what we do, and rosin works fine as a flux for what we do.
kcuf   100 W
Post by kcuf » Jan 30 2019 9:46am
soldering very easy to practice free scraps of comparable wire components abound
practice until full confidence of outcome before attempting important workpieces
In 2013 an ad appears on Russia social networks: Интернет-операторы хотели! Работа в шикарном офисе в Ольгино !!!, зарплата 25960 рублей в месяц
flat tire   1 MW
Post by flat tire » Jan 30 2019 4:07pm
Buy a tube of flux in addition even tho you're getting rosin core. Apply the flux liberally to all metal you want to add solder to in advance. It will make getting the solder to adhere to the surfaces you need it on extra easy. Sure flux core mostly does the same thing but the limited amount of flux can make it difficult for beginners.
docw009   100 kW
Post by docw009 » Jan 30 2019 9:06pm
Don't use silver solder. It's what Home Depot sells to please the anti-lead crowd. It requires a higher temperature iron. Probably needs a torch to melt properly.
E-HP   100 kW
Post by E-HP » Jan 30 2019 10:59pm
Lovelock wrote:
Jan 30 2019 4:18am
I agree with the guidance above on the solder.
But to clarify, are you cutting and splicing the wires and cables, or soldering on new connectors? Either way a smaller iron will do, since for the big wires (phase and battery) it's probably better to cut then crimped on new connectors. The rest of the wires are small, so a smaller iron is easier to manage and control the amount of solder you're applying. For electronics, I like the adjustable models.
Remember to buy some shrink wrap.
Lovelock   10 W
Post by Lovelock » Jan 31 2019 6:57am
E-HP wrote:
Jan 30 2019 10:59pm
Lovelock wrote:
Jan 30 2019 4:18am
Thank you for all the responses!
My plan is to cut out a section of the wire and solder back together, without touching the original connector.
The power cables wont actually be cut, they are pretty short as it is.
I'll see what non lead free solder I can find, Amazon doesn't seem to have much (UK)
Volt_Ampere   10 W
Post by Volt_Ampere » Jan 31 2019 10:02am
Smaller signal wires are easy to solder - you don't need a super powerful iron. Use heatshrink to cover the connections - not tape. Do get good 60/40 or similar lead/tin solder with rosin core. Make good mechanical connection by twisting the conductors together before soldering.
izeman   100 GW
Post by izeman » Jan 31 2019 10:26am
The advise for 60/40 lead solder was given before, and i +1 this.
Also do yourself a favor an buy some BRAND solder. DON'T order solder from China. I did, and threw all of it away again. The good brands cost a bit more, but also have the stated ingredients and a good flux core. Soldering will be much more easy.
And the 100W soldering iron with A BIG tip is great for soldering phase wires and stuff.
Post by spinningmagnets » Jan 31 2019 12:49pm
I agree with izeman. Brand name solder might cost twice as much as generic Chinese solder from aliexpress, but...it's still very cheap. Crappy solder is a pain and it wastes your time trying to get a good joint.
If you don't have a preference yet for a specific brand, try Kester (although I am sure there are other reliable brands)
https://www.amazon.com/d/Soldering-Prod ... ster+63+37
Lovelock   10 W
Post by Lovelock » Jan 31 2019 2:46pm
spinningmagnets wrote:
Jan 31 2019 12:49pm
Is there a potential for a soldering iron to be TOO hot for smaller wires? The main ones I wan't to shorten are the motor 9 pin cable and the PAS. These both contain thin wires.
Also, any chance you could recommend a brand of solder on the amazon.co.uk site :lol:
izeman   100 GW
Post by izeman » Jan 31 2019 3:35pm
https://www.amazon.co.uk/Weller-40-25-E ... 1548966655
1mm thick. Works good for most application.
Yes. If a soldering iron is too hot the resin will burn off, and the tip will suffer. If you aren't soldering too often a non regulated soldering iron will do, but you get regulated ones with exachangeable tips quite cheap:
https://www.amazon.co.uk/Soldering-Iron ... ering+iron
This one looks like it has tips big enough to store some heat. A small tip will cool off too quick when it gets in contact with a thick wire. So imho the bigger tip is more important than wattage.
mark5   100 kW
Post by mark5 » Jan 31 2019 4:15pm
Lovelock wrote:
Jan 31 2019 2:46pm
Looks like you'll have an easier time finding solder with lead in it on UK eBay than Amazon.
Also get a brass wire soldering iron tip cleaner like the example below. They work better than a wet sponge.
https://www.ebay.co.uk/itm/BT-Soldering ... 2128264649
izeman   100 GW
Post by izeman » Jan 31 2019 4:36pm
mark5 wrote:
Jan 31 2019 4:15pm
Good hint. A wet sponge will destroy your tip in no time. Cooling it off all the time causes micro fractures. Those wire sponges are great. I use them for years now. And always remember: When you're done with soldering, clean your tip, and cover is completely with fresh solder and let it cool down. This solder will seal the tip and prevent it from corrosion.
fourbanger   100 W
Post by fourbanger » Feb 15 2019 9:40pm
That right there is some good advice that I was previously completely ignorant of.
Thanks izeman.
+1 on staying away from cheap ebay solder. I want my $2.49 back.
Don't know why you need to source out your solder on amazon though; just pop into her majesty's radioshack or whatever have you. It's not particularly esoteric stuff.
Maybe a bit OT but what are people's take on soldering GUNS around here? I seemed to think that I didn't like them, then ended up using an old sears 100/140 a little while ago and really didn't mind it at all. Little bulky, maybe, but it's nice to have that kind of power and I like being able to put it down just about anywhere without worry of burning everything to the ground. Meh
amberwolf   100 GW
Post by amberwolf » Feb 15 2019 10:33pm
Depends on what you're soldering, and how.
The guns can take significant time to reach temperature, and don't have much thermal mass (and what they do have is out in the open with a lot of surface area to radiate the heat away rather than store it to conduct into the joint).
If you have to use it by holding it on the joint while pulling the trigger because of that, well, many things in electrical or electronic stuff will probably suffer from the prolonged heating effects.
Theyr'e also generally large and heavy, and I'd rather use a lightweight pencil type that I can have finer control over. :)
fourbanger   100 W
Post by fourbanger » Feb 16 2019 12:58am
That seems like a fairly astute appraisal. Interesting point about thermal mass. I put together a battery pack a while back using a 100 watt soldering iron with a pretty sizable chisel tip and while it went alright I kind of felt like another 40 or so watts of heat would have been nice. Having said that, I can't help but feel I was still better off with the 100w iron than 140w gun...
izeman   100 GW
Post by izeman » Feb 16 2019 4:30am
This is my favorite soldering iron for up to AWG8. Found it on Ali. Note the big tip.
electricwheels.de   100 W
Post by electricwheels.de » Feb 16 2019 2:58pm
For signal wires 0.14mm² and 0.2mm² I would use 40/60 leaded electronics solder 0.7mm diameter.
Even with these small signal wire diameters, I use a medium sized soldering tip that I clean with metal wool.
Here some instructions on how to join a signal cable.
Custom made cables and wiring harnesses for e-bikes. HIGO and JULET connectors, extension cables and much more. World wide mail order.
e-bike-technologies webshop
